if you don't mind....i'm trying with the full license...but the problem still there.
the version is the latest available
[c4d] material node problem/frozen
Well! I'm curious to see what's the problem. It may help to other if we know.lorenzospinolaCT wrote:if you don't mind....i'm trying with the full license...but the problem still there.
- lorenzospinolaCT
Good morning.
nothing, i kept to try but it's getting worse.
update also for the user that may have the same problem: after i spoke with aoktar we tried to delete other plugins( vray and pvrenderqueue).
i thought the problem was solved, but it didn't.
i'm trying on a new blank scene, nothing there.
i create a new octane diffuse material, i open the node editor and i drag and drop the imagetexture node.
i try to connect the image node to the diffuse channel, after that the line connection stays green and cinema doesn't respond
