Hi to everyone guys,
just bought my new laptop asus rog 502 with a gtx 1070.
i'm starting saying that i'm using the full license on my workstation in the office without problem, unless few chashes sometines.
here it's almost impossible to work.
when i try to oper the material window it takes more or less 30 sec to be available.
after it is, if i open the node editor i have the same problem...every time i try to change some setting c4d look frozen and take 20-30 secs to be normal again.
is this a problem only with the demo problem?or a common one?
i'd like to try with the subrsciption version but i don't want to waste money if the problem persist in that version as well.
thanks for helping,
enzo
[c4d] material node problem/frozen
Do you have big textures or lot of c4d shaders in this materials? Disable material and opengl previews and test it.
- lorenzospinolaCT
Hi aoktar,
thanks for your reply.
actually i don't. the scene is white and i'm placing the first material. the vram is about 360Mb/8 gb.
can you tell me where to disable the material and opengl preview?
Ok so forgot what i said for previews. This is not expected result as you can estimate from other pc.lorenzospinolaCT wrote:Hi aoktar,
- lorenzospinolaCT
i tried anyway,
with preview, in nodes, off didn't change.
with openGL off didn't change.
i didn't try with both off yet.
but the weird thing is that didn't happen when i was trying the demo on my old laptop, even though the GPU was the 860M and now i have the 1070
What do you see in console output on load? Did you removed unnecessary octane. plugin versions?
- lorenzospinolaCT
this is what i see in the consolle:
Loaded Octane DLL:OctaneRender 3.04.3 Demo version:3040300
Octane Render Demo for Cinema 4D 3.04.3
Octane Render SDK version: 3.04.3
[VB NOTE:] hash 0aa1892
in the plugins folder there is only the demo version, and i left only the r18 license because i have c4d R18
It may be about your hardware or version that you're using. I've notified that's old demo and not matching latest stable (3.05.3).
- lorenzospinolaCT
Hi aoktar,
that is weird because i downloaded yesterday the demo from the otoy website.
i try again hoping the version is problem.
thank you very much, i let you know if i will resolve the problem
Np! We can check it by remote connection if you'll still need a help.lorenzospinolaCT wrote:Hi aoktar,
