Phantom Architecture 1.1.0 is now available!
Visit the website here:
http://architecture.phantomtechnology.nl/» Fixed problem that made the program crash when pressing the 'Cancel' button when browsing to a *.OBJ or image file.
» Added new MODE called UV-SCALE CORRECT.
» UV-scale correct: added function IMPORT IMAGE (under IMPORT / EXPORT). This allows you to import the image used for referencing.
» UV-scale correct: added function INTERPOLATION (under MAIN). When this is enable, imported images are rendered using interpolation.
» UV-scale correct: added function SOURCE WIDTH. This defines the width of the indicator texture used for the texture mapping (from SketchUp).
» UV-scale correct: added function SOURCE HEIGHT. This defines the height of the indicator texture used for the texture mapping (from SketchUp).
» UV-scale correct: added function EXPORT OCT SCALE NODE. This allows you to export the result of the UV-SCALE CORRECT mode. It creates a scale node on the clipboard with the scale factor you need. Simply press CTRL+V in Octane Render standalone after export.
» UV-scale correct: added function TARGET LENGTH. Here you enter what the real life scale of the length indicated using the target line would be.
» UV-scale correct: added functions RESET SOURCE and RESET TARGET LINE.
» UV-scale correct: added function RESET VIEW.
