Attic environment
Forums: Attic environment
Attic environment
Postby grimm » Thu Feb 16, 2017 7:18 am
grimm Thu Feb 16, 2017 7:18 am
I have been working on an attic environment that I would like to use as a virtual studio for several subjects. This is what I have so far.
I'm having some kind of uv issue with the brick wall. I have tried everything I could think of to fix it, short of recreating the wall. Any ideas?
Jason
Linux Mint 20 x64 | Nvidia GTX 980 4GB (displays) RTX 2070 8GB| Intel I7 5820K 3.8 Ghz | 32Gb Memory | Nvidia Driver 460.56
grimm
Re: Attic environment
Postby Marvez » Thu Feb 16, 2017 5:39 pm
Marvez Thu Feb 16, 2017 5:39 pm
Hi Jason,
good start, positive criticism is .. :
1. Scale of space seems off
2. lack of depth in displacement / bump in all three surfaces wall , floor, roof
3. window looks cut out and miss the opportunity to give the all depth by being flat (maybe a little bigger or a tracery window for add dynamics
hope this helps
Best
WM
I7 5820K 16MB RAM SSD850PRO GTX 970/780
Marvez
Postby grimm » Thu Feb 16, 2017 6:47 pm
grimm Thu Feb 16, 2017 6:47 pm
Thanks WM, I agree, I have been struggling with the scale. I'm going to scale down the rafters and the roofing boards, hopefully that will help. The window does have a frame and sill, but I haven't put the window in yet. I can bump up the displacement as well.
grimm
Postby grimm » Fri Feb 17, 2017 7:45 am
grimm Fri Feb 17, 2017 7:45 am
I rescaled the rafters and added a bit more depth to the displacements. I also changed out the floor texture for hopefully a better one.
Tomorrow I will add the window and I have some other plans as well.
grimm
Postby grimm » Sun Mar 05, 2017 12:12 am
grimm Sun Mar 05, 2017 12:12 am
Life has been busy and I haven't had much time to work on this. But here is an update. Finished the window frame and reworked the floor so it interfaces with the other elements better. Next is the window glass and a light.
grimm
Postby grimm » Sun Mar 05, 2017 12:32 am
grimm Sun Mar 05, 2017 12:32 am
Ooops, noticed a UV error on the floor, here is a fixed version:
grimm
Postby grimm » Wed Mar 08, 2017 5:08 am
grimm Wed Mar 08, 2017 5:08 am
Still working on the light, but I did render another view with the new V3 test version.
Finding it hard to find good old worn looking floor textures. This one is the best so far, but it still has issues, but they might not matter too much.
grimm
Postby grimm » Thu Apr 20, 2017 6:55 am
grimm Thu Apr 20, 2017 6:55 am
I haven't been very active here as I have been really frustrated with finding good textures that fit my scene. I saw that Allegorithmic finally made a Linux version of Substance Designer and Painter. Combine that with their awesome subscription "Substance Live" where you pay $20 monthly until you have the software payed off and then you own it, I just couldn't pass it up. :D
So I have been delving into the software which is very deep, especially Designer. I have been testing it with some artifacts you might find in an attic, like a hammer:
Lots of fun, and this allows me to custom build the textures I need without spending a ton of time and money finding the right textures. The hammer was textured with the default substances that come with the software and others from the substance source site.
grimm
Postby MF-lda.Italy » Mon Oct 23, 2017 6:48 am
MF-lda.Italy Mon Oct 23, 2017 6:48 am
Just about texturing, I recently found another product from Allegorithmic called B2M that work so well to properly define physical tailored textures.
Very good looking results with few hours training.
Hope it helps..
MF-lda.Italy
Postby grimm » Wed Oct 25, 2017 6:40 am
grimm Wed Oct 25, 2017 6:40 am
Thanks, unfortunately I can't use B2M as it's Windows only and I run on Linux. The good news is that they are rolling all that B2M does into Designer, so I should be good then. :)
I'm hoping to start working on this project again, now that winter is here in Alaska I should have a lot more time to work on it.
Jason
grimm
Next
Return to Works In Progress
Users browsing this forum: Flau and 8 guests
Thu Mar 28, 2024 2:49 pm [ UTC ]
