round edges question
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
WhyGee
Hi
I've noticed that when I have a shader with round edges > 0, even when the rop is set to update and material update is disabled there is a long preprocessing delay when jumping between frames with the IPR running or just batch rendering a sequence. The geo with the round edge shader has no animation update (no time dependency) but is quite dense, around 10 million polys. shouldn't the preproc occur only once? most of the render time is lost on preprocessing, the actual render itself is like 20% of the total frame time. Without the round edges the preproc is at least half of when it's on.
Any advice on how to speed this up? would using the standalone provide any advantage?
Yaniv
juanjgon
I wasn't aware off longer pre-processing times related to the round edges feature, but perhaps Octane needs to compute extra data to support it. If you want to send me the scene, I could test it here to see if something can be done to improve this issue.
Anyway, the pre-processing is done by the Octane core, and usually, there is nothing that can be improved from the plugin side, unless something wrong in the plugin is forcing a complete scene pre-processing. I could check using your scene.
WhyGee
I think it's only noticeable on large scenes. Maybe something wrong with my scene so I'll check again.
I'll try to prepare a scene in the following days to send you.
WhyGee
I've attached a test scene. Even without round edges it seems to be doing some long recalculating on static geometry which is not supposed to happen no?
without round edges:
I goto frame 1, fire up the IPR takes approx 15 seconds on my machine.
while IPR is running I jump to frame 100, preprocessing takes another 13 seconds to update.
with round edges:
frame 1, start IPR takes 38 seconds for preprocessing.
IPR open jumping to frame 100 takes another 33 seconds before updating.
any way to speed this up would be great. because in the original scene I'm also using the Cd -> UV workflow, instancing isn't an option.
Yaniv
round_edges_scene_update1.rar
(16.74 MiB) Downloaded 258 times
juanjgon
I'm testing your scene here and you are right, with the round edges feature enabled the scene preprocessing time is at least twice longer. It is the preprocessing time in the Octane side, so I suppose that some extra computation is needed in this phase to render the round edges.
Anyway, the problem with the slow IPR update among the frames is that you probably have the IPR full update options enabled. The IPR window has four square switches (D, M, I and V) that are enabled by default. This means that the update of the objects Deformations, Materials, Instances or Volumes is enabled. If you disable these switches, the update time is almost instantaneous.
WhyGee
I see, I thought it would detect none deforming geo and not update when not necessary. Is that not the case if there is atleast one other deforming object in the scene, the whole scene is updated?
juanjgon
Yes, currently if the update mesh deformations option is enabled, all the meshes are updated. Anyway, if any mesh changes its topology, the Octane scene must be preprocessed again.
WhyGee
If possible it would be incredibly useful if there was an option on an object level to control whether to update or not.
Yaniv
Return to “Bug Reports”
