Hi guys,
just wondering if im struggling here through inexperience with the upgrade to the newest version.
I can seem to see the materials when i click on the properties tab.
I thought it would pop up and give me access to importing the live DB etc etc.
I can get it to show the material sphere only by selecting 'by object' not by layer.
I can also go to setting and load the material tab as a separate one on the far right but this doesnt seem very efficient.
Am I doing this the long way? Just seems a bit complicated.
Cheers
Tim
Material editor questions
Hi Tim - have you checked out the manual page at https://docs.otoy.com/manuals/products/ ... rials-tab/? It explains how to add new Octane materials and accessing the LiveDb.
Hi Paul,
Yes quite a few times but its not doing what it says.
There is no load from DB button underneath the materials node editor as per the manual
I cant find the "change all materials to octane materials" button to swap from rhino to octane materials
I get nothing if i go to the Rhino object properties button and select my object. if i look onthe rainbow donut it tell me its an extrusion etc, but if i select the materials paint tube button there is nothing. I can only get infor if I bring up the paint tube materials button as a separate tab across the top as per the images I attached.
Not sure if that makes sense but yeah , I have been through the materials instructions a few times and it doesnt seem to do what its should.
Cheers
Tim
Cheers
Tim
Hi Tim - is it possible you are looking at the wrong manual? And am looking at the link I posted above and it covers your questions....
Hope that helps.
See the "Importing/Exporting Materials" section of that manual page - the screenshot shows the LiveDb menu option in the Import menu.There is no load from DB button underneath the materials node editor as per the manual
Quoting from that page....You can also convert ALL non-Octane materials used in the scene to Octane materials using the “Convert All Materials To Octane Materials” rightclick option on the plugin Settings tab.I cant find the "change all materials to octane materials" button to swap from rhino to octane materials
I suspect you have the material assignment by Parent rather than Object. As per the manual link posted above...."IMPORTANT: The OctaneRender plugin requires Rhino geometry items have materials assigned By Layer or By Object. Assigning materials By Parent may give unexpected results."I get nothing if i go to the Rhino object properties button and select my object. if i look onthe rainbow donut it tell me its an extrusion etc, but if i select the materials paint tube button there is nothing.
Hope that helps.
