[X-position] problem Daz > Octane
Moderator: BK
ClairObscur
Hello,
I expecting problem with objet (Wings) who dont follow the position of DazStudio in the Octane Viewport. Do anyone had this trouble before ?? the wing is an .pmd objet format. In the picture you can see in DazStudio the position is right, and the position isnt good in the Oc Viewport (like X-Pos) I tryed to reload forced, or re-open the duf file.. is always the same trouble.
Daz 4.9 - Octane 3.4.5.29 used.
Any help ?
Intel Core I7-3770K | 16Gb Ram | Gigabits GTX 970 Overclocked 4Gb DDR5| SSD Crucial Adrenaline 64Gb | W7Pro 64bits | Octane 3.x + OCDS 3.x
Leonides02
I've encountered this issue on other objects. Typically a "Force Rebuild" solves the problem.
abayliss
I have encountered the issue as well. In some cases a a single force rebuild, or even a re-starting daz does seem to fix it.
I haven't done much testing, but I think it could be related to grouping objects and then moving the group. It doesn't happen that often, but when it does it's annoying.
Windows 10 Pro 64bit, i7-8700 3.2 GHz, 64GB RAM
2 x RTX 2080ti
It would be worth using the latest TEST build (3.5.3.30) of the plugin, since it corrects some issues related to prop placement.
ClairObscur
Thank you guys for your answers. Also thank you Face_off for your quick reply. I updated to the 3.5.3.30 and tryed again. At first the bug was again here but i "rebuild Scene" and all is ajusted Right now :)))
So all work !
Sincerly,
C.O
Return to “DAZ Studio”
