Octane/C4D stops with error on animation
archiform3d
I have an issue that appears from time to time and then with some random messing around eventually goes. It's causing me pain again so I need a fix.
I set up animations to batch render, all Octane scenes in C4D, and if the render que is interrupted either by something like a power failure or me having to stop it, then sometimes from that point on none of the animations will render beyond the second frame, with a report of "out of memory". There is plenty of spare memory, so it's something else.
I can provide more information if someone has any ideas. I have a job to get out the door and this is killing me.
No need to be killed! Just you have to know somethings about processing of plugin. Why it works fine in LV and happens in PV?!! Do you ask? What's different between two of these? I'll explain the difference if you give details for your render settings and LV options.
