Hello,
I have a 1080 that I'm using for rendering. The 780 ti I as just using for my monitors.
I sometimes switch from standalone to Modo/Octane render but notice a lag on the modo side.
Can you take a look at the is capture and let me know if I've done this setup correctly? If you can explain what changes you would recommend, that would be amazing! Still a little unclear about the choices.
(Sorry for the crappy image but I couldn't take a proper screen capture in Windows as the pop up window would close when tried to take a capture!!!).
Thanks in advance.
Are these options accurate/efficient?
Yeah this seems to be fine. It's best to use one card only for screens while other to render.
Thank you!
