OctaneRender for Carrara 3.08.03.42[Stable and Test]
Forums: OctaneRender for Carrara 3.08.03.42[Stable and Test]
Carrara (Integrated Plugin developed by Sighman)
Re: OctaneRender for Carrara 3.05.01.31[Test]
Postby PhilW » Thu Jan 05, 2017 9:16 am
PhilW Thu Jan 05, 2017 9:16 am
I was thinking on a per object basis - but if there was also a global control to say "Increase/decrease the power of all emitters", that could be a useful option as well!
PhilW
Postby Sighman » Tue Jan 31, 2017 7:33 am
Sighman Tue Jan 31, 2017 7:33 am
PhilW wrote:Sighman - Happy New Year! Not an issue, but a request. I have been working recently with surfaces which have a texture map in the glow/emission component. I need to set these up with Carrara's shaders but would ideally like them to render in Octane Render too without having to adjust them all each time I render - there are a lot! The default conversion from having a texture in Carrara's glow channel into Octane's Emission channel seems to give a very low value for the emission, of 0.03, which is almost equivalent to having no emission at all.
Would it be possible to have a look at this and change the default translation from Carara shader's glow to Octane Material's Emission to something that looks broadly equivalent? Also if there is a multiplier on the Carrara side, so Multiplying a texture map by say 250%, could you use this to adjust the strength of the Emission automatically in Octane?
I hope this will be an easy task and something that you can build into the next major update. No worries if not, I can do things manually, but having a good automatic translation would be a real time saver (and hopefully useful for other Octane for Carrara users as well!).
I have added a number of new features to support this. Under Octane Environment I have added two new sliders. Global Emitter Scale and Carrara Emitter Scale.
Global Emitter Scale affects all Octane mesh emitters.
Carrara Emitter Scale only affects emitters that are auto created from a shader's Glow channel.
I have also added a new Octane Multiplier shader that you can add to a Glow Channel (or any other Channel). The Octane Multiplier has two inputs (Input and Scale). The Input input takes a Carrara shader, while the Scale input takes an Octane Texture shader. For a Carrara native render, the Scale input is ignored. For an Octane render the Input is multiplied by the Scale. This way you can adjust the Emitter power of the Octane render without affecting the Carrara native render.
Win8/64, I7-4770K (3.5Ghz) 24GB, GTX-980ti (6GB) / GTX-TITAN (6GB)
Sighman
Re: OctaneRender for Carrara 3.05.03.32[Test]
Postby PhilW » Tue Jan 31, 2017 8:24 am
PhilW Tue Jan 31, 2017 8:24 am
Thank you, thank you, thank you! I can't wait to try this!
PhilW
Postby PhilW » Tue Jan 31, 2017 8:51 am
PhilW Tue Jan 31, 2017 8:51 am
I noticed that you have also added a Tasks section, but could not work out where it is, and how you would use it. Do you have an example of it's use?
PhilW
Postby Sighman » Tue Jan 31, 2017 3:35 pm
Sighman Tue Jan 31, 2017 3:35 pm
Sighman
Postby PhilW » Tue Jan 31, 2017 4:40 pm
PhilW Tue Jan 31, 2017 4:40 pm
Great, thanks - new Emitter Scaling stuff seems to be working well!
PhilW
Postby EddyMI3D » Wed Feb 01, 2017 6:27 pm
EddyMI3D Wed Feb 01, 2017 6:27 pm
Hello Simon!
The Tasks feature works really fine. Pushbullet is useless on iPhones this moment, so I'm working on a possibility to send emails.
I just try to find out where the initial scene (that one, that appears when "New" is used) is stored to keep the contents of "Executables" and "Arguments".
My Rig:
PC with AMD FX 8350 @ 4,00 GHz
Win 7-64
Nvidia GTX 760
Nvidia GTX 970 (only for rendering)
About 6 TB of disk space (768 GB of SSD)
Octane/Octane for Carrara
EddyMI3D
Re: OctaneRender for Carrara 3.06.00.33[Stable]
Postby Sighman » Fri Apr 14, 2017 10:15 pm
Sighman Fri Apr 14, 2017 10:15 pm
New plugin version (3.06) posted to this thread.
Sighman
Postby EddyMI3D » Mon Apr 17, 2017 6:58 am
EddyMI3D Mon Apr 17, 2017 6:58 am
Great! Thanks a lot Simon!
My Rig:
Win 7-64
Nvidia GTX 760
EddyMI3D
Postby protovu » Mon Apr 17, 2017 2:16 pm
protovu Mon Apr 17, 2017 2:16 pm
Working nicely, Simon.
Is there any action we should take regarding CUDA 8? Update card drivers?
Triplanar mapping ...wow. Looking forward to learning it.
protovu
PreviousNext
Return to Carrara
Sun Jun 16, 2024 7:37 am [ UTC ]
