Hi can I control the level of AO, I know - but it sometimes I absolutely don't need when I'm working in Direct mode ... Ao I'm doing Dirt //// I can't exclude the AO from the scene .... I need to exclude from AO beauty .... I do feels bad ... and earlier in the Octane render 1.beginning of 2.x it was
now I get pass AO + I AO pass on beauty ... I understand that I have to make more passes and make precomps but I often don't need beauty enough . . .
long time Octane render 1.x Sample mode Environment off mode AO - and now there it is always enabled
if the octane renderer thinks it should be and this is now true, I cease to remember what it was .... Do not hesitate to write we want to discuss
OctaneRender® for 3ds max® v3.05 - 4.29 [OBSOLETE]
When Octane window open, and press F10 (render setup) then 3dsmax crash !!!
I found the problem with crash - AO infopass
this problem is only Path Tracing kernel mode and PMC
- Elvissuperstar007
- Contact:
this is a normal display HDR
this is one of the most confusing decisions that I've seen
Fstorm. Vray . Corona. Red Shift. Mentalray. Arnold. Scanline --- normal display HDR
- Elvissuperstar007
- Contact:
Bitmap / Photometric Path Editor and Resource Collector
viewtopic.php?f=82&t=58121
- paride4331
Hi Elvis,Elvissuperstar007 wrote:this is a normal display HDR
you're right when you say confused,
you're using Octane 2.26
We are using 4.29
Let's make a road map . . . let's communicate with users
then all the negativity will disappear
now - true ? what the change will go to 4.30
what is planned to fix and what to add from past queries to optimize the plugin? if the task fails for any reason the task is transferred to 4.31( and will not forget about it)
from the original scene began to collect a new one when you press the render max's murder - I don't know what led to the crash test ... but the fact remains - not only the AO leads to the murder of max - where there is still an error
dropped to 4.29 in the debates no longer take part, came down to 4.25
