Version 3.05.3 (13.01.2017)
atome451
Hi Aoktar,
If i remember well, it was working fine in previous versions. Very older ones, i didn't tested this recently.
If i try to drag and drop a null object or a camera as External transform to a Projection node in the Node editor, it doesn't work, i'm unable to drop it on the input field or even type the name in this input field. If i drop it in the same input field in the Attributes panel or material editor, it works.
With complex nodes structures, it could be very usefull to work only with Node editor. :)
Here a screen capture:
Win10 64bits | 3x 980 + 2x 670 + 1060 | Cubix XPander + network | Core i7 3600 MHz | 32GB | 1300w PSU
Sorry for my bad english...
davidtorpey
Hi
Random colour doesn't work on any version of 3 that I have tried.
Any luck on fixing this?
Cheers
David
NVN wrote:
max383 wrote:Hey ! Nothing important but on Cinema4D R18.039 everytime I close the program I got a message about an Octane plugin crash. But that's just when I'm closing C4D, and the scene is not saved in the bugreports.
+1
the same goes for me
On previous version? Any bugreport?
atome451 wrote:Hi Aoktar,
I haven't tested that but you have to know this is not about me. I just call a open dialog command in c4d. I believe it's a c4d issue and it should be not supporting somethings.
davidtorpey wrote:Hi
Cheers
David
Did not see or hear any issue for that. Are you sure that you're using it correctly? It will work on RENDER INSTANCES not else.
Hi guys,
I would like to show what i'm doing for NE right now. I believe new small changes in NE that will make much easier to work in. And I can do this kinda improvements when i feel less stressed after a good release. And would be great to hear any opinions about NE right now. So i can evaluate some of those.
Best,
Ahmet
2017-01-22_4-27-25.mp4
(2.54 MiB) Downloaded 4511 times
davidtorpey
Silly me....
Thanks all working fine...
:D
uncia
aoktar wrote:Hi guys,
I would like to show what i'm doing for NE right now...
Best,
Ahmet
Killing features . Thanks
brasco
This looks very interesting Ahmet,
The grouping is very welcome.
I can only think of a few minor improvements that would help me when using the NE.
  • 1. Optimize (auto scale) for nodes would be helpful to quickly reduce the size of nodes based on their content:
    Here's that function in Xpresso:
  • 2. Gradient previews, similar to how the C4D gradient node displays when you enable previews:
    Top is how Octane gradients preview, below is the C4D gradient
    Maybe something like this would be nice, and not having the square preview so it fits the shape of the node better too.
  • 3. Undo for the NE in general, not just the main commands, I mean layout and connections.
  • 4. Have the attributes/parameter pane collapsible with a single shortcut/button would be really helpful too:
  • 5. Snapping to the grid, or maybe an Align to Grid command like in Xpresso:
  • 6. Detatching node connections is tricky at the moment, you can only do it by click dragging the input end and releasing.
    Having an option like Alt+click or Shift+click to delete the connection would be cool. Houdini has a useful one which is shake to detach, that's one I miss in every other nodal interface when it's not there :)
  • 7. Maybe rounded corners and a 1px grey border for unselected nodes, just as minor cosmetic improvements would help.
Let me know if you want me to clarify anything, those are just things that have occurred to me when using it.
Keep up the good work!
cheers,
brasc
Rig#1 Win 10 x64 | GTX 1080Ti | GTX 1080Ti | GTX 1080Ti | i7 7900K 4.7GHz | 64GB
Rig#2 Win 10 x64 | GTX 1080Ti | GTX 1080Ti | GTX 1080Ti | i7 3930K 4.4GHz | 32GB
Rig#3 Win 10 x64 | GTX 1070| GTX 1070| GTX 1070| i7 2600K 4.8GHz | 32GB
atome451
aoktar wrote:I would like to show what i'm doing for NE right now. I believe new small changes in NE that will make much easier to work in. And I can do this kinda improvements when i feel less stressed after a good release. And would be great to hear any opinions about NE right now. So i can evaluate some of those.
It seems to be really great! I want it! :D
Some suggestions:
1/ when you ungroup a group, it could be usefull to have the nodes automatically selected. This way, you could immediately move the nodes to an empty space of the NE board.
2/ it could be very usefull to be able to cut and paste these groups in another materials of course. Maybe it's already the case?
3/ in a marvelous world, a double click on a group would open another tab in the NE for fine tuning the content (like the double click on a group in standalone)... :mrgreen:
4/ a SHIFT+click on a node to add it to a node selection could be usefull.
5/ a shortcut+click to activate or desactivate preview could be usefull too.
Anyway, thanks a lot!
Return to “Releases”
