Phoenix fd 3 support.
remKa
You can export to OpenVDB files with the last PhoenixFD buid now
AMD 9950x3D / RTX 4090 / RTX 3090 / 192 Go DDR5 / Win 11
http://www.remy-kerbiquet.com
coilbook
remKa wrote:You can export to OpenVDB files with the last PhoenixFD buid now
Could you tell me how to do it. I thought Phoenix saves sims files as AUR Thank you!
coilbook
Dear Otoy team,
sorry for bugging you again. We are about to start a complicated project with fire, smoke and liquids. Could you at least tell us if you are planning to add phoenix 3 support when octane 3.1 will come out? That way we kind of know at least an estimate when?
Thank you !!!!
ThaRaven
Under Export change it from AUR to VDB in Phoenix FD 3
Win 7 64 | Geforce GTX780 |Dual X5667 Xeon | 40GB | MAX 2016 |
coilbook
Hi. I exported fire and smoke as vdb. Then in phoenix 3 where it says input I chose that vdb sequence and octane is not showing it in renderer. is there any way to add octane volume to phoenix 3 or how do i render vdbs using phoenix 3 Thank you!
coilbook
i wish otoy would just add that octane volume modifier to phoenix 3 like they did for 2.2
ThaRaven
use the octane vollume Object. No Modefier as of yet
coilbook
ThaRaven wrote:use the octane vollume Object. No Modefier as of yet
I ma sorry to bother you again. Do you know by chance how to add octane volume object in 3ds max?
Thank you
paride4331
Hi coilbook,
coilbook
paride4331 wrote:Hi coilbook,
Thank you
But i still cannot those VDBs that I created Phoenix 3 to show up in the renderer
I created VDBs with phoenix 3
loaded them into octane object
added medium
Return to “Autodesk 3Ds Max”
