How do I create a transparent background?
haknslash
I need to save an image without the background.
I have unchecked the Alpha Channel in the Octane kernel settings and in my Octane Viewport I can see the transparency grid instead of my background, so far so good. However when I click the "port to max framebuffer" so I can save the image file the alpha channel is black and not transparent. How do I retain a transparent alpha for the background?
900D | 4770k | ASUS Maximus VI Extreme | 2x RTX 2080 Ti's | 32GB RAM | AX1200i | Win 7 64bit | Autodesk Inventor | 3DS Max | Blender | Mudbox | Alias
HHbomb
save image to .tga or .tiff ( a format which have alpha possible )
paride4331
Hi haknslash,
or PNG.
As HHbomb rightly says, all formats provided with alpha.
haknslash
I have tried PNG and Tiff. I think the issue is with the plugin and not necessarily the steps. I say this because if I export the 3DS Max file to Standalone Octane I'm able to enable alpha background and the transparent background works but if I try this in 3DS Max I will always have a black background regardless of settings or file type save.
The same thing happens when I try and hide a ground plane but retain shadows by assigning a matte material. In 3Ds Max the ground plane is still visible with shadows but if I export the 3DS Max file to Standalone Octane the ground plane is hidden but the shadows remain as intended.
paride4331
Hi haknslash,
there is no issue, just a matter in 3dsMax framebuffer preview, but not in OctaneRender viewport.
Saved image has the alpha chanel (not .jpg of course).
Elvissuperstar007
Pre multi alpha
nobody writes. that it is necessary to include this check in the chamber, This smoothing edges
Return to “Autodesk 3Ds Max”
