CUDA error 700 on third GPU
jejeaudio
Hello,
I have 3xGTX1080 installed in my case.
Cinema4D R16 and latest octane version.
I have the third card wich make the render fail.
With only 2 cards, everything works perfect, but as soon as I ask the third to render with the others, octane make a cuda error 700.
I have tried on very simples scenes, and It works with the 3x GPU.
If I try to render with only the third, It don't works, even simple scenes.
Here is the log:
Scene created in plugin version -1
Export materials time= 21.135 ms
Collect objects time= 53.166 ms
Mesh creation time = 41.373 ms.
Triangles:0 Disp.triangles:0 Hairs:0 Meshes:0
VRAM used/free/max:0Kb/0Kb/0Kb
Out-of-core used:0Kb total used RAM:6.968Gb
Total export Time = 143.463 ms
CUDA error 700 on device 2: an illegal memory access was encountered
-> kernel execution failed(report)
-> failed to launch kernel(ptBrdf2)
device 2: direct light kernel failed
device 2: detected an error on render device! trying to recover...
-> failed to deallocate device memory
-> could not get memory info
-> failed to unload module
-> failed to bind device to current thread
device 2: failed to initialize resources
device 2: failed to recover - giving up and switching device to failed
<<< Render failure detected!!! >>>
Please check render statistics to solve the problem.
Triangles:12 Disp.triangles:0 Hairs:0 Meshes:1
Device:0 TotMem:8Gb rtData:0Kb film:0Kb geo:0Kb node:0Kb tex:0Kb unavailable:0Kb temperature:44
Device:1 TotMem:8Gb rtData:0Kb film:0Kb geo:0Kb node:0Kb tex:0Kb unavailable:0Kb temperature:44
Device:2 TotMem:8Gb rtData:0Kb film:0Kb geo:0Kb node:0Kb tex:0Kb unavailable:964Mb temperature:50
Any idea ?
Is it broken ?
Win 7 64Bits - Octane 3 - Cinema4D R15
i7 920 - dual GTX 1080 - 24Go ram
On last days i've seen a lot of similar cuda errors. And mostly on 1080s. See another posts. I'll point this topic to core devs.
Btw what's your brand/models? Links for cards? Maybe overclocked?
jejeaudio
Gigabyte G1 gaming.
They are not overcloked, they are slightly downclocked.
But figure what: I've just tried to make the third gpu perfectly stock (no over or down clock, power at 100%)
-> it works... (for now)
I'll let you know if something change !
jejeaudio wrote:Gigabyte G1 gaming.
That's great!
I think Cuda is much more sensitive to errors than game engines.
Gwrath
I have also been getting this error suddenly as well as error 999, 799, and a few others, I have everything from 1080s to 1060s 980ti and 980 machines getting these errors. I get them on something as simple as a new scene with a box.
Any help is greatly appreciated as I can't render anything on my farm and have a project due soon.
I am on windows 10 on all computers involved, geforce driver 378.92 ( as well as tried several older drivers, all had same issue)
thanks
slepy8
In my opinion Cuda error 700 could be related to a faulty card.
I had them too. With multiple cards setups.
Finally my system works stable without issues, after I threw away 780Ti.
My system is now 2 X 980Ti and a 780 6GB. So I'm mixing Kepler and MAxwell (it's been said that it's not good to mix different architectures).
Now I can run thousands of frames over night without any problem.
Also do not overclock or downclock. Use MSI Afterburner and set everything at stock level.
