Hello there!
It seems that skinner and x-particles are not rendering properly (octane no supporting XP cache - but it's another question)..
The Main problem is that in Cinema LV and in Octane LV are showing the same result, but on render the geometry and positions of particles are quite different from the desired result.
p.s.
I put an octane tag on emiiter and skinner also
Cheers
X-Particles 3.5 Skinner Problem
Check your cache, fps, etc.. There's no reason to be different. Also there's not any logic like that's XP cache is not supported. Plugin will render any triangulated geometry which is provided by system. It doesn't regenerate or evaluate somethings. If you still need help pls post a scene to show problem.
My main problem is not the cache =)aoktar wrote:Check your cache, fps, etc.. There's no reason to be different. Also there's not any logic like that's XP cache is not supported. Plugin will render any triangulated geometry which is provided by system. It doesn't regenerate or evaluate somethings. If you still need help pls post a scene to show problem.
Please help me to solve this problem with different geometry and particles positions on LV's and final render.
fps are same in render settings and project settings also
Always post some detailed info. We lost much time to ask same questions. Versions/OS/scenes/etc...
aoktar wrote:Always post some detailed info. We lost much time to ask same questions. Versions/OS/scenes/etc...
Window 8.1
i7 4790
32 gb
2 x 1080 gtx
cinema 4d 18
x-particles 3.5
octane 3.04.5
scene attached - for similiar results pls run simulation until frame 50 or something
Cheers
- scene example.rar
- (1.38 MiB) Downloaded 165 times
I stucked at home due snow. I'll check when go to office. But i don't estimate that's about our plugin. It's a type of geometry and we render what provide the c4d system. Plugin doesn't care how it's created or which type.KillReal wrote:Hope Aoktar will take a look at it also...RealGrupa wrote:I renderd your scene, and have same situation as u.
Hey i am not trying to blame a plugin or something) Probably - i just forgot to tweak some settings - but i still need your attention on this problem)aoktar wrote:I stucked at home due snow. I'll check when go to office. But i don't estimate that's about our plugin. It's a type of geometry and we render what provide the c4d system. Plugin doesn't care how it's created or which type.KillReal wrote:Hope Aoktar will take a look at it also...RealGrupa wrote:I renderd your scene, and have same situation as u.
You are always doing it great!
Cheers!
Hello there!
3 days left - any news?
