Discoball scene
bratro
I'm trying to create a simple discoball, with reflections on the wall with one sharp spot light. Sounds pretty simple but I don't know how to achieve that ;-(
This is the look I'm trying to create:
(Discoball, spotlight & reflections on the wall)
This is my current test scene:
My Render Settings:
Metalic material for the ball:
My questions are:
- How to create a sharp spotlight with octane. (currently it's only a plane with a blackbody emission which gives light to the whole scene, but I wont it only on the discoball)
- How to make the reflections/caustic much more visible in the scene?
- In general, what settings should be changed? What should I do different?
The scene can be downloaded here:
https://dl.dropboxusercontent.com/u/580 ... -test.orbx
Thanks for your help!
whersmy
hi!
rendertimes get quite slow, PMC is the way to go.
used an ies spot light, which renders out slower but gives a good lighting definition!
I think the trick is to decrease the emitters` size, concentrate the lightsource, and just wait. First few samples nothing clears out, but after a while the reflections become visible. Perhaps to get even more out of it you could try an small plane emitter inside a open tube, that as well generates a nice concentrated beam of light.
GI clamp on 1000 leaves out most hotpixels, and adjusting the gamma brings out the reflections.
discoball_v2.orbx
(3.26 MiB) Downloaded 708 times
Octane 2022.1.1 nv535.98
x201t - gtx580 - egpu ec
whersmy
Let this one render out overnight to 32k samples, interesting scene!
bratro
whersmy wrote:Let this one render out overnight to 32k samples, interesting scene!
AMAZING!
Exactly what I was looking for. Thank you so much for your help!
I definitely have to learn how to use these ies lights as I'm not at all familiar with it, but they seem very powerful ;-)
whersmy
Glad to help out! It`s just a standard .IES, you could try a distribution emitter as well.
greets!
jmd
Hi, is there a way to get a IES to mimic a disco ball to cut on render times? Cheers!
Return to “Works In Progress”
