The update e-Mails are being sent out in this very moment you should all get yours soon!
With RedSpec TGX tailored MK3 we want to give back to the community and our supporters, by making it totally free.
The shader structure was greatly revamped and contains (amongst other detail changes)
- 8 Specular Maps to better distribute skin glossiness effects
- A completely re-designed eye, teeth and nail shader
- 2-click-presets
- Normal & Bump map inclusion in the same shader layout.
The MK3 shaders require a reinstall, so please reinstall through the setup file included in the .zip.
They also contain a .zip-folder called extract_to_DS_content_folder.zip - please unzip this into the folder where you would typically install your DAZ Studio content into.
To use MK3 please make sure that you get the most recent OctaneRender for DAZ Studio plug-in here: https://render.otoy.com/customerdownloa ... _Win64.exe (MK3 will NOT work with older versions of the plug-in)
Please also refer to this video guide explaining the changes: https://vimeo.com/196940156
Happy Rendering
EDIT: Added changes that came with the release of the free G8F update
