Houdini save pass render
Houdini Integrated Plugin
fabiodamico
Hi I can't save separate render passes!
i am trying to create a render to png with all the separate pass....
in exr I managed without having the pass of oc??
Thank you very much
juanjgon
So your problem is that you can't save PNG files, but you can save EXR multi-layered files, right?
What plugin version are you using. A problem related to saving render passes as PNG files was fixed in the 3.04.0.0 build.
fabiodamico
Hi ,
I installed version 3.04.4.0, now I have the problem that when the pass motion vector from render deactivates the blur...something wrong?
Thank you very much
This is with the pass motion vector on
This is with the pass motion vector off
juanjgon
This is the expected behavior. If you enable the motion vector pass, all the beauty passes are rendering without motion blur to make possible add the motion effects in post.
mauropetrelli
i am trying to save the passes separately in png and it doesn't work i have version 2020.1.3.0 and houdini 18.0.460
juanjgon
mauropetrelli wrote:i am trying to save the passes separately in png and it doesn't work i have version 2020.1.3.0 and houdini 18.0.460
How are you configuring the output file name? You need to add the $OCTANE_PASS variable to let the plugin export the right filename for each pass.
galleon27
It also needs an extension cause it doesn't work without it. So $OCTANE_PASS.png
Win 10 64bit // GTX 4090 + GTX 3090 // 5900x // 64GB // SideFX Houdini // C4D
Return to “Houdini”
