Great.KonstantinosD wrote:well what do you know, it worked! Weird that the official adobe extension manager was failing..
Thanx smicha
PS. Update your footer, 7x...
Thanx smicha
Hi,KonstantinosD wrote:Can you please fix the octane Photoshop plugin to work with PS 2017, at the moment I can not install it.
Thanx,
Konstantinos
Hi Abstrax,abstrax wrote:That was done on purpose to make the beauty filter passes and info filter passes consistent. In previous versions, the alpha of info filter passes was depending on the material type which didn't make sense at all. Since you don't need the alpha channel to apply the filter passes, we decided to make disable alpha for the info filter passes the same way it's handled in the beauty filter passes. For what would you use the alpha channel?tschwenke wrote:Hi,
I just installed the new version. Now, the "Beauty transmission filter" and the "Material transmission filter" look exactly the same!? In the previous version, there was a difference between those passes. When I used the "Material transmission filter," I had an alpha channel and only the transmission material has been displayed. Now, it's all black...
Best wishes,
Thomas
