Octane Render for SketchUp 3.04.4.5 Stable Release
CaptainCrowbar
This release is primarily for compatibility with SketchUp 2017. This version is now compatible with SketchUp 2015, 2016, and 2017; the installer currently defaults to SketchUp 2016, but you can select one of the other versions during installation. Apart from updating the Octane SDK to the current release (3.04.4), there are no other changes from the previous stable release.
This is just an interim release with minimum changes made to get a SketchUp 2017 compatible version into customers' hands as soon as possible; a test release with major new features related to the node graph system will be made shortly.
Installation Notes
The 2.x and 3.x plugins cannot be simultaneously installed with the same copy of SketchUp. Installing the 3.x plugin should replace the 2.x plugin if you already have it, although we recommend uninstalling any existing plugins first. If you install the 3.x plugin and want to go back to 2.x, you will need to fully uninstall the plugin before reinstalling 2.x.
Please note that stable releases will not be identified by any special version numbers. Because of potential compatibility issues if different builds of the Octane engine are run on the same system, we believe it is more important to keep plugin version numbers synchronised with the corresponding build of the standalone Octane application and the Octane SDK. If you are having problems, the first thing you should check is that you do not have different versions of other Octane 3.x products installed.
If you have problems installing or uninstalling the plugin, please try the uninstall assistant and see if that helps first.
Major Changes (since 2.x)
* The plugin is now compatible with SketchUp 2017. It remains compatible with SketchUp 2015 and 2016.
* Like the Octane 3 standalone version, the SketchUp plugin uses the new single sign-on system. You still need to have purchased a license for the SketchUp plugin, but it will now be checked automatically when you log in using your Otoy account credentials; you no longer need to keep track of user IDs and passwords for individual licenses.
* Because most rendered images are now stored in your computer's main RAM instead of your video card's RAM (see the section on host film buffers in the Octane 3 feature list here), all Octane 3 applications, including the SketchUp plugin, will frequently use a good deal more memory than their Octane 2 equivalents, especially for high resolution renders. You should keep this in mind when upgrading.
* The new authorization management window is a modal dialog where the user can sign out and sign in. It also informs the you under which name you are signed in and if that sign-in was in offline or online mode. When a user signs out, all of your licenses which were activated on this computer will be deactivated. This requires that all these licenses are currently not in use by other Octane processes. If that's not the case the sign out will fail.
* Because of ongoing changes to the license management system, you should avoid mixing different 3.x Octane installations on the same computer. Please make sure that all Octane standalone and plugin installations are the same version. (Expect this to be relaxed in future releases.)
* 3.03+ releases include experimental Pascal GPU support. Please note that we are still working on performance issues there.
* Support has been added for the Skatter plugin's Render Only mode.
Recent Bug Fixes
* In Skatter's render-only mode, scattered objects should now be reliably rendered in the Octane window.
* Scattered objects will now be rendered regardless of whether or not the original object is hidden.
* Better synchronisation between Octane and SketchUp rendering of Octane materials. This will fix many of the cases where you change the parameters of an Octane material, and see the change in the render window, but not in SketchUp. Because SketchUp materials don't support all the features of Octane's materials, it isn't always possible to make the appearance of a material in SketchUp exactly match the way it's rendered in Octane, but the plugin will now make a better attempt to show a good approximation.
* Adjusting the UV transform in an Octane material should now re-scale the material in the same way in both SketchUp and Octane.
* A texture scaling issue that sometimes caused textures to be rendered much larger or smaller than their correct scale has been fixed.
* Undoing and redoing changes in SketchUp will now be more accurately tracked in Octane.
* Closing and re-opening the Octane render window should no longer cause it to freeze up.
* Octane license menu now correctly opens the new license manager window.
Known Issues
* Re-applying the same texture after an undo may fail to work. This is a bug in SketchUp, not related to the Octane plugin.
SketchUp Version
- The plugin requires SketchUp 2015, 2016, or 2017 for Windows x64.
- SketchUp 2016 is recommended.
- If you are using SketchUp 2015 or 2017, remember to select this when installing the plugin.
- The plugin is not compatible with any x86 (32-bit) version of SketchUp.
System Requirements
- 64-bit Intel or AMD CPU.
- Microsoft Windows 7, 8, 8.1, or 10 for x64.
- One or more recent model Nvidia GPU cards.
- Nvidia drivers 353.x or later; CUDA 7.5 support is required.
More Information
- SketchUp plugin manual (3.0)
- New features in Octane 3.0 (manual)
- New features in Octane 3.0 (forum)
- Octane 3.0 release notes
- Octane 3.04.4 release notes
- Post your questions here on this forum thread!
Support Information
- Operating system (e.g. Windows 8.1 x64)
- Amount of RAM
- Graphics cards - model (e.g. Nvidia GTX 690 with 4GB)
- Nvidia driver version (e.g. 365.10)
- SketchUp version (e.g. SketchUp Pro 2016 version 16.1.1449 64-bit)
- Skatter version (if you have it installed; e.g. Skatter 1.2.0)
- OctaneRender for SketchUp version (e.g. 3.04.4.5)
Download Links
- Current 3.x stable release
- Current 3.x stable demo release
- Current 2.x release
- Current 2.x demo release
Release Notes
3.04.4.5
- Compatible with SketchUp 2017.
- Build with Octane 3.04.4 SDK.
3.04.0.0
- Build with Octane 3.04 SDK.
3.03.4.9
- Fix failure to render objects from Skatter library.
3.03.4.7
- Improved Skatter support.
- Improved synchronisation between Octane and SketchUp material appearances.
- Fixed UV scaling and other texture scaling issues.
- Undo/redo now more reliable.
- Closing and re-opening render window should not trigger Flash freeze.
- License menu updated.
3.03.3.2
- First stable release of 3.0 series.
- Added Skatter support.
- Compiled with Octane 3.03.3 SDK.
- Fixes for texture scaling issue and various other bugs.
3.03.2.3
- More changes to file path code.
3.03.2.2
- Tweaks to internal file name manipulation code to avoid save errors due to invalid paths.
3.03.2.1
- Rewritten shutdown process to address license deactivation issues.
3.03.2.0
- Compiled with Octane 3.03.2b SDK.
- Changes to file path handling code to address issue with user home directories on network paths.
3.02.0.0
- Compiled with Octane 3.02.0 SDK.
3.01.1.0
- Compiled with Octane 3.01.1 SDK.
3.0.1.21
- Compiled with Octane 3.01 release SDK.
- Added authorization management window
3.0.0.20:
- Compiled with Octane 3.0 release SDK.
3.0.0.4:
- Compiled with Octane 3.0.0 beta 4.
- Added a demo version.
3.0.0.1:
- Compiled with Octane 3.0.0 beta 1.
- Internal changes to texture rendering, LiveDB access, and licensing for compatibility with Octane 3 API changes.
Last edited by CaptainCrowbar on Wed Jun 13, 2018 4:08 am, edited 1 time in total.
Jorgensen
Still not possible to run more than one instance of octane render :-/
haze
Thanks for that Jorgensen. CC is looking into this now
fivebythree
Octane window isn't displaying anything, just blank screen. Updated nVidia driver today. Do I need to update flash player?
Edit - Flash isn't the culprit, neither nVidia driver.
STANDALONE+STUDIO WIN11PRO | RTX3090 | XEON 4210 20 CORE | 96GBRam
haze
fivebythree wrote:Octane window isn't displaying anything, just blank screen. Updated nVidia driver today. Do I need to update flash player?
fivebythree, a few questions -
Has this happened only since installing the nvidia driver?
Have you tried it with a simpler scene, and did it work?
Were you able to use Standalone successfully?
Are you on Windows 10, 8.1, 8 or 7?
SU 2016 or 2017?
Thank you
fivebythree
Happened with a previous driver. I don't always update them.
Yes, just a plane and a box - still nothing.
Yes. I've been using it for pretty much every render lately. This has been a problem on my laptop for a while see specs in my sig
Win 7 home
SU 2016 or 2017?
pro 2016
Tried exporting an orbx from the blank screen - none of the nodes are connected.
I think I may have to revert back to an older version. This vis is on a ridiculous deadline.
fivebythree
Now on office PC, similar results.
Return to “SketchUp”
