I am creating hair instances inside Octane Object Tag.
I have hairs in the Live Viewer but the caps are not textured. Is this a bug?
Hair Caps
No, it's hole. That's how it's. You can use scaling effect in hair to close taps.JavierVerdugo wrote:Is this a bug?
- JavierVerdugo
The texture is a emitter full light. If this is a hole, it should be iluminated by inside right?. I have the texture tag Side "Both".
emissions work on front face not back.JavierVerdugo wrote:The texture is a emitter full light. If this is a hole, it should be iluminated by inside right?. I have the texture tag Side "Both".
- JavierVerdugo
Thanks for your time Aoktar. Didn't know about that limitation.
Regards!
Regards!
