I do not know what the problem is.
Scene of other similar settings will work properly rendered.
Cuda 719 randomly generates an error later in 830 Frame of the Scene.
The version 3.03 and version 3.04, both occurred. My graphics card is Maxwell Titan X.
The interesting fact is well rendered by Pascal Titan X version 3.04 and spew errors that had so far.
Change already the fourth day option to keep the same frame as the problem of'm testing graphics cards to change the setting, or do not know what the problem is that Scene.
View looking up as the log file.
If you want want to receive my work files Please inform us about your personal storage space. 1.7GB Space
Help! Octane.Log
- octane.log
- (4.28 MiB) Downloaded 187 times
So do you have always this problem in the same frame? One good test to try to reproduce the problem is to open this frame in the IPR and export it to the Standalone as an .orbx file that we could test here.
Anyway it is weird that the same frame could be rendered fine in the Pascal GPUs. Do you have only one Maxwell GPU? ... perhaps the problem could be a hardware issue with this GPU. Of course if you have other Maxwell GPU with the same problem, can't be a hardware issue.
It does not occur in the same frame.juanjgon wrote:So do you have always this problem in the same frame? One good test to try to reproduce the problem is to open this frame in the IPR and export it to the Standalone as an .orbx file that we could test here.
While some frame appears progress is the same, but the error always occurs on the low point, such as log files.
And my system has the same error appears even three Titan, and activated one by one.
It caused to other systems. I have a total of 12 Titan X, but appears random error associated with the GPU without fail. All the same symptoms. If the hardware is the problem of water during the first two tasks of the Scene that I will still be working properly rendered.
I feel like the problem is not clear ..... Tree Instance.
If I turned off the whole Instance should operate normally. But I am a normal Instance should take if a problem less than 1 frame ....
And kernel:InfoChannel is normally rendered without error.( IDMask Pass Render)juanjgon wrote:So do you have always this problem in the same frame? One good test to try to reproduce the problem is to open this frame in the IPR and export it to the Standalone as an .orbx file that we could test here.
It is hard to say what could be the problem. If you want to send to me the scene to test it here, I could try to reproduce it. You could use https://www.wetransfer.com/ or something like this if the file is too long.
If you say that disabling the instancing all works fine, perhaps the problem is that you have a lot of instances in the same place, or near the same place. Be sure that you don't have overlapping instances in the scene.
Send Email
