OctaneRender® for 3ds max® v3.03.4 - 4.22 [OBSOLETE]
HHbomb
sorry not to be enough precise : vray convertion all
wisemanxxx
I realized that there is no problem while objects which have converted materials (old 2.2 octane materials converted , not vray or other) are hidden. When I unhide them max hangs after save (normal save or auto backup) .
solomonfl
This build breaks my 3DS Max 2017 licensing, had to revert back to 4.21
is anybody else using max 2017 getting that same error?
Elvissuperstar007
HDR instance imports in material Editore ...breaks 3dmax
paride4331
@wisemanxxx
could you kindly share a scene (if you prefer in pm) where it reproduces your issue?
In point prior to unhide.
shall I have the converter activated when I open the scene?
paride4331
@HHbomb
Hi HHbomb,
cheked issue.
Tinkle
+1
2016 3ds max, simple models with vray materials.
when i press convert button it broke 3dsmax.
paride4331
Hi Tinkle,
cheked issue.
Just sent to developers.
Elvissuperstar007
returned to 21, this release is very buggy
paride4331
@Elvissuperstar007
Hi Elvissuperstar007,
I'm trying to reproduce the issue you report but it does not happen.
Could you kindly attach a scene where issue happens and some screenshots or a video about it.
Return to “Releases”
