How do i choose certai nslave GPUs?
coilbook
Hi We have a slave with 3 1080s. We do not want to use he main GPU that is conencted to the monitor. How do i tell slave to only use 2 bottom video cards? Thank you
abstrax
coilbook wrote:Hi We have a slave with 3 1080s. We do not want to use he main GPU that is conencted to the monitor. How do i tell slave to only use 2 bottom video cards? Thank you
When you install the daemon, you can specify which GPUs should be used.
coilbook
Hi I tried and i could not. do I just type GTX 1080, GTX 1080. and i have three of them how do i tell it to use two secondary GPUs and not primary one?
Thank you
Hi coilbook,
you don't need to specify the model of your GPU but the number of GPU, from 0 to 2 in your case. From the manual:
-g <int>,  --gpu <int>  (accepted multiple times)
 add GPU device to use for rendering (0 = first)
ciao beppe
coilbook
bepeg4d wrote:Hi coilbook,
ciao beppe
hi i still cannot get it to work. Could you tell me exactly what to type to get two secondary video cards to be used and the top one on the motherboard not to use thank you
Itypes 1, 2 and it used primary one and the third one on the motherboard If i type anything else like 0,1 or 0, 2 Slave just wont run
it says which GPUs should be used Please keep default or enter a coma/space separated list"
abstrax
ciao beppe
Please post a screenshot of the device tab (File -> Preferences... -> Devices) of the Standalone on the slave and highlight all device that should be enabled. I will then let you know what to enter during the daemon installation.
coilbook
ciao beppe
Hi.
HEre is the screenshot. we do not want to use the card that is connected to the motherboard Thank you
abstrax
coilbook wrote:Hi.
All GPUs are connected to the motherboard. You probably mean the GPU that is not connected to any displays. There is no way I know of, that would allow Octane or me to figure out which GPUs are used for displays. The only way would be to enable each, render a complex scene and see for which GPUs the GUI performance drops noticable.
Anyway, the daemon installer asks for a list of GPUs that should be used by the slave. You have 3 CUDA GPUs so the possible GPU indices are 1, 2 and 3. If you want to disable GPU 1, you would enter 2,3. If you want to disable GPU 2, you would enter 1,3.
coilbook
abstrax wrote:
coilbook wrote:Hi.
Thank you !
Return to “Commercial Product News & Releases (Download here)”
