ORC Access
Discussion forum for OctaneRender Cloud
Paulzebra wrote:Hello guys!
I really confused about how to render animation from Cinema 4D via ORC. I don`t understand what`s wrong and why I have 1 rendered frame only instead of bunch of frames. Just to save your time I recorded video process. ;)
https://yadi.sk/i/07reSx5LugSnV
Yes best to ask me.
Older versions of plugin doesn't support any material/texture/object tag/etc.. animations. Just geometry animations.
With 3.04 Marcus added new exporter and i've adopted plugin for new system. Now it should be able to export all kind of animations, i hope! It just not yet support volume objects.
Your mistakes here, of course it's my bad also due unsufficient info.
1-Set range from timeline not from render settings
2-Set octane.exe for your pleasure and checking exported scene before send to ORC. This is most important step because you should be sure that's exported with full range of animation and correct content.
3-Don't use yet "Cloud send" command. Use LV->ExportTo->Animated ORBX and check exported scene in standalone. Then send it manually. Set size/format/etc.. in ORC menu and render.
4-Use 3.04-R1 version.
Export things will be still on my focus to fix/improve because we just did such work until now. It was a long adventure to make lot of changes until now. And I'll check the issues if you inform me.
NesTega
Hello! I would like to gain access to the OctaneRender Cloud. It's real?
eyeonestudio
That's Really Good News
I want demo :D
Thanks...
C4D R2025 / Win11 / AMD TR WX Series / 256Gb RAM / RTX3090 / 100GbE
fuzzybro
eyeonestudio wrote:That's Really Good News
I want demo :D
Thanks...
Hi @eyeonestudio, just shoot us a message with you OTOY account info to [email protected] and we'll hook you up
DJ-Dazbo
How do I donate to the ORC, my 3 desktops are currently sat idle.... and the idea that they're being used to render portions of animations and help out the industry sounds fantastic.
DJ-Dazbo wrote:How do I donate to the ORC, my 3 desktops are currently sat idle.... and the idea that they're being used to render portions of animations and help out the industry sounds fantastic.
for this, you have to look at RNDR, not ORC:
https://rendertoken.com/
ciao Beppe
Return to “OctaneRender Cloud”
