Animation just stops switching frames
LFedit
Hey Paul just wondering if you got a chance to look at the scene file. Sorry for rushing, but would be great to have it ready for the weekend.
Also, is it possible to render a seq of specific frames? I am going to do more research on it now.
Win 10, Threadripper Pro, Dual 3090s
Yes, I have the scene file, but also a lot of work to do for the 3.04 release. I will hopefully get to your scene in the next day or two.
LFedit
Completely understandable. I know how you feel about a lot of work. That is why I am asking so many questions so much. Got a project to do about 80 backgrounds for a half hour long video. With a short deadline. Cruising along though. Thanks for your help.
I had a look at the scene you sent me, and I run out of RAM during the Voxellization process when trying to open the Octane Viewport. So my guess is that when the plugin is reloading the next frame it's running low on RAM and disk swapping. How much RAM do you have? What is the Windows Task Manager reporting as the amount of free RAM during the animation process?
LFedit
I have 6gb of GPU ram and 64 of System Ram. I had to turn on out of core textures.
But still. It loads perfectly fine for me when I just open the viewport and render a frame. I can then switch frames and reload and it works perfectly fine. The only time its doing this is when I run 2 frames in a row as an animation.
May I suggest watching the Windows Task Manager during the frame swap process to see where RAM is at - it might provide a clue.
LFedit
Hey Paul. Here is a screenshot while it is switching frames. Shows that I am not even using all of my RAM.
It seriously though takes about 35 minutes to reload the geo. I am going to try the saveAnimation command. Hopefully it doesn't take forever to import into the standalone? This is killing us right now. We would get like 20 shots done a night but instead maybe get 10...
I can see network use spiking. Do you have Network Rendering enabled?
LFedit
Yeah. I saw that too. And its going to 6 nodes. But still it doesn't make sense to work if I manually click the reload geo button compared to it just switching between frames though right?
Do you get the long delay switching frames if Network Rendering is OFF?
Return to “Foundry Modo”
