OctaneRender™ 3.0 for Houdini™ - production build 3.03.4.0
Angelos
I think it's a problem with Deadline 'cause in Afanasy render manager it works fine by default.
Thanks anyway
juanjgon
Yes, could be. You should report this issue to the Deadline team to see what they think about it. Of course if they need help with the plugin, let me know.
Shelest
gui2one wrote:Hi Juanjo ,
I just updated to this release ( 3.03.4.0 ) and I have a nasty error message : "Failed to export render passes discrete files"
It worked just fine just before the update ( with version 3.03.2.1) .
I tried with png or exr output, all the same.
Has something changed in the pass rendering system ?
I have a same error:( build 15.5.480
juanjgon
Yes, sorry, It has been fixed for the next build, that I want to release early next week. Do you need this feature just now?
Shelest
No, Thank you. Previous version works fine.
fantome
I have the exact same error on
- Houdini 15.5.565
- Windows 10 x64
- Octane 3.04.03
 *** OCTANE API MSG: ERROR: failed to export render passes discrete files
Cheers
E
EDIT:
it looks it's a mistake i've done because i was
- trying to write images to a directory that doesn't exist yet
- i have the checkbox 'create intermediate' directories uncheck
Now it looks to work like a charm ... my bad !
Return to “Releases”
