Remove IES file
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
remKa
Hello,
when I put an IES file into an OctaneIESLight, I can't remove/copy/past it with right click menu.
Thank you in advance !
AMD 9950x3D / RTX 4090 / RTX 3090 / 192 Go DDR5 / Win 11
http://www.remy-kerbiquet.com
paride4331
Hi, remKa
I do not think the issue is a bug.
You would have the same issue with right click, as well with other render engines.
Delete a IESfile also not needed, you can not use the Octane IESlight without an IES file.
remKa
Hello,
it's not a bug but neither a request so I posted that here ;)
You actualy can use an Octane IES without any file in it.
I used "remove" in my subject's title but I shouldn't, my point is that sometimes I need to swap or copy/paste IES file from an OctaneIES to another, but I can't do it simply by right clicking
paride4331
Hi remKa,
the copy and clear command could improve the octane workflow.
I will try to check if it is a 3dsmax issue or it can be solved in octane 3ds max plugin.
Thanks for the support.
remKa
Thank you very much !
Return to “Bug Reports”
