OctaneRender® for 3ds max® v3.03.4 - 4.20 [OBSOLETE]
neonZorglub
Plugin's version string consists of two parts - version of Octane core integrated into this version of plugin, and the version of the plugin itself.
This is the test release with new features implemented, so some issues are expected. Please report the bugs in the "Bug reports" section.
Changes of the 4.20 version
  • fixed conversion of gradient texture
  • fixed conversion of main Camera Aperture, Focal depth, Dithering, Lens Shift, Min disp. samples
  • fixed proxy flag not recognized (now both 'octane_movable_proy' and 'octane_movable_proxy' are read, same for 'Octane_layer_ID' and 'octane_layer_ID')
  • fixed conversion failing to be activated (still grey materials in 4.19, where was working in 4.18..)
-- Mini guide to this new integrated conversion system: --
Purpose: Load max scenes containing octane objects and materials created with octane plugin version 2.23.2 - 1.9 and earlier.
-Conversion system need to be activated first. 3dsMax need to be restarted for this activation / desactivation to take effect.
-The 'Activate' check box let you select the activation status; a message 'Change will take effect on max restart' is shown as needed.
-On the left of this check box, the current activation status is displayed.
-Note: this 'activation' may use a little bit more memory for the converted scenes. Once saved, and reloaded, this should come back to normal.
It is recommmended to keep the system deactivated when no conversion is needed.
-Minor changes in render result are to be expected, mostly due to evolution of Octane renderer itself, and maybe in incomplete old parameter conversion (that would be issues to be fixed).
-A good way to check if the conversion is fully correct is to export the scene from the 1.9 plugin as orbx and visualy compare the result between the standalone and the 4.18 plugin.
Notes:
Loading an old scene with the conversion deactivated seems to occasionally cause some issues.
-> The conversion system should really be activated when loading old scenes.
Some crashes have been experienced, likely caused by ProSound items in the scene, randomly overwriting some memory..
-> disabling the ProSound plugin / removing sound items from scene solved the issue.
Previous versions changelog (since major 4.0 plugin release):
Changes of the 4.19 version
-Loading of 2.23.2 - 1.9 and older scenes with material conversion fully supported.
-Added conversion dialog in 'Tools' tab. See tooltips for more details.
Changes of the 4.18 version
-Loading of 2.23.2 - 1.9 and older scenes with material conversion support added. This should remove the need to use the external material converter !
-Fixed crash when using Reaction Manager with octane materials.
Changes of the 4.17 version
-New 3.03.4 rendering core.
-Fixed Black screen rendered when using Free Camera.
-Always enabled button to logout in Account tab.
-Added statistics in render window (object, face, light count).
-Changed CPU memory usage stat in Viewport to show used/maxi of 'out of core' reserved memory, instead of total estimate usage.
-bugs and memory leaks fixes.
Changes of the 4.16 version
-New 3.03.3 rendering core. Volumes export must work stable now, plus there are some other fixes in this new rendering core version...
-Added new "visible..." attributes for visible environment mode of daylight object.
Changes of the 4.15 version
Changes of the 4.14 version
Changes of the 4.13 version
Changes of the 4.12 version
- Unlocked the plugin's feature I've implemented a long time ago, responsible for loading the vertex velocities channel data into Octane rendering core if a velocity channel is present in an object of interest and if this channel is filled with a correct data by this object. This will not work for any 3ds Max (or thirdparty plugins) objects that do not have velocity channel exposed or fill it with faulty data (I've not seen the ones that do it correctly so far, perhaps you will find some). You can now find "Velocity channel ID" field in "Octane properties" of objects. Loading of velocity channel data into the Octane rendering core is disabled if this field has value less than "2" ('cause channel "0" is always "vertex colors" and channel "1" is a first UV channel).
- Fixed a bug: Octane OpenVDB object crashed if a chosen VDB file path did not exist.
Changes of the 4.11 version
- Implemented the width/height settings for textures' viewport preview buffer.
- Now when "Render Map" is used for Octane textures the result has the desired resolution chosen in the "Render Map" dialog.
- Textures preview is now refreshed in 3ds Max viewport after changes are made.
- Implemented a translation of "crop/placement" parameters for native bitmap textures in materials converter.
- Implemented a translation of image sequence parameters for native bitmap textures in materials converter.
- Fixed region rendering bug in final render mode.
- Fixed the fluctuating bug: sometimes the interactive rendering got endlessly refreshed if turbosmooth modifier had been applied.
Changes of the 4.10 version
- Fixed image textures camera mapping for movable proxy objects.
- Materials converter now retains viewport-active texture.
Changes of the 4.9 version
- New 3.03.2 rendering core.
- Implemented the targeted/untargeted modes for Octane camera (e.g. usable for perspective match tool).
- Now you can set the quality for materials/textures previews (new "Mat. preview spp" field in Octane render settings).
Changes of the 4.8 version
- New 3.03.1 rendering core.
- Far clip is now supported by camera.
Changes of the 4.7 version
- Implemented the workaround to make the "Place highlight" functionality work. Use the new "Flip" attribute in Octane light object. It is a good practice to have this checkbox enabled in any new Octane light you create. It only needs to be disabled by default to not get all the lights flipped in your old scenes.
- Fixed a bug: artifacts sometimes when 3ds Max native textures were used as Octane image textures input.
Changes of the 4.6 version
- Improved the new "Save image" functionality of Octane interactive viewport. Now the render elements are given names and saved automatically.
- Improved the IES distribution visualization feature: now some melformed IES files are understood by the plugin.
Changes of the 4.5 version
- Implemented a direct saving of current content of Octane viewport into image. See a new "Save image" button in a toolbar.
- Fixed one more issue of distribution visualization of some specific IES files for some specific locales.
Changes of the 4.4 version
- PhoenixFD simulator object without OctaneVolume modifier applied is now considered a mesh by Octane. This is usable if you tend to enable "Show mesh" in it and render it as a mesh, not as a volume.
- Fixed IES distribution visualisation bug appeared for some specific locales.
Changes of the 4.3 version
- Implemented new kind of Environment - "Visible environment". The existing Octane DayLight object ideology is changed. Now you can use up to two of those objects in a scene - one for main environment and one for visible environment (the new "Kind" attribute). And now you can set either of those to either "Daylight" or "Texture" environment type (the new "Type" attribute). In this case, if the main environment node is set to "Texture" type - it will replace the Octane environment map set in 3ds Max standard settings (if any).
- Added error logging to IES visualisation functionality. If you have issues with displaying IES distribution in 3ds Max viewport - attach please the Octane error log to the bugreport.
Changes of the 4.2 version
- Fixed image textures bug.
Changes of the 4.1 version
- Implemented the PhoenixFD simulator support. You need to apply the new "OctaneVolume" modifier on top of simulator object to have access to additional Octane-specific settings. Mapping of PhoenixFD channels to Octane: temperature -> emission, smoke -> apsorption -> scatter, and velocity -> velocity.
- Implemented a feeding of Octane image textures by non-Octane textures input. Now not only BitmapTex can be connected to "bitmap" attribute of Octane image textures. In this case the new "Bake input scale" and "Bake input resolution" attributes of Octane image texture must be tuned accordingly. But I still advise you to not abuse this approach too much, and still use the old efficient way: manually baking the texture to the file and use this file in created Octane image node. Because in the latter case you will do this manual baking only once - when you are creating the texture. But when you use this "on the fly" texture baking approach - the plugin will render (using standard 3ds Max CPU-calculated nodes) and bake every such texture every time during scene translation. So, if you have quite a few of such textures with high baking-resolution set - it will significantly increase the scene translation time. My measures for just one 3ds Max "Marble texture" show about 67ms rendering and baking it into 512x512 image buffer, and about 1500ms to do the same into 4092x4092 image buffer. Multiply this by amount of your non-Octane textures in the Octane scene - and you will get the overall slowdown time of every translation stage (the CPU-stage before Octane even starts to render on GPU).
Changes of the 4.0 version
- Implemented the support of "Time" settings of standard BitmapTex when it is connected to any of Octane image textures. "Sync Frames to Particle Age" currently is not supported - this needs the support on Octane rendering core level.
- Implemented advanced file sequence settings for Octane image textures and volume object. The "digits number" setting only makes sense when direct file sequence is used (not an IFL file). The "end condition" makes sense only when IFL file is used. The "start frame" and "playback rate" are used in both modes.
- Textures preview now respects the timeline position when generated.
- Implemented the distribution visualisation for Octane IES lights having target. See the new "IES distribution visualisation" section in Octane settings.
You can read about new features of OctaneRender™ 3.0 here:
viewtopic.php?f=33&t=51679
DOWNLOAD
OctaneRender for 3ds Max 3.03.3 - 4.20
DEMO version:
OctaneRender for 3ds Max 3.03.3 - 4.20 DEMO
viewtopic.php?f=24&t=55733
kevinshane
Awesome Job neon and azen!! you guys really make my day!! in fact, this convertion will bring more and more octane users back to using octane 3ds max plugin again~~ :P :P
little tiny suggestion here, maybe you guys should post a BIG WORDS and maybe a stick to the Announcements panel so that to remind people the new 4.20 has been successfully converted the old scene..I recently got many emails for customers asking how to convert the old scene, clearly they don't see forum detail recently and some of them miss the new covert version, so a clear obvious announcements maybe could do this job~
anyway thanks again! awesome job!!
Shane
MSI GT70 laptop i7-3610QM+32G+GTX680M 4G
Octane Arch/Interior Viz Tutorials
http://www.kshane.com
coilbook
Thank you!
is there anyway to preserve animation. Like we had police lights animated using Mix material value in old version. is there anyway to keep animation after conversion. Thank you!
coilbook
kevinshane wrote:Awesome Job neon and azen!! you guys really make my day!! in fact, this convertion will bring more and more octane users back to using octane 3ds max plugin again~~ :P :P
Shane
I agree. We have not switched for a long time because of all the headache converting hundreds of models and scenes
coilbook
Now hopefully you guys can solve the old problem of no motion blur for liquids in 3ds max. Hopefully Autodesk will respond to otoy and help solve this vector problem.
haze
coilbook wrote:Now hopefully you guys can solve the old problem of no motion blur for liquids in 3ds max. Hopefully Autodesk will respond to otoy and help solve this vector problem.
The last we heard from Autodesk was that they have escalated the issue report to their engineering team - hopefully we will see a solution shortly!
HHbomb
Hi, I have a lot of crash when saving image with this version.
paride4331
Hi HHbomb,
could you report further details to understand your issue?
HHbomb
@Paride
when saving jpg from octane viewport with the top left button it often create a max error and then max shut down. 3dsmax 2017 -sp3
coilbook
when rendering with newest version slave fail all the the time. It cannot even finish frame 1 then master quits rendering. 3ds max must be restarted or it will be black screen and no rendering progress if render button is pushed again
we use a lot of itoo forest trees
looks like it fails when rendering trees
Return to “Releases”
