Hi, this is my first post here - so maybe expect some dumb questions.
I'm currently building a new computer with importance being placed on being able to run Octane as fast as possible (and within budget). Being the sort of guy that would normally spend around £50 on a graphics card, it came as a bit of a shock to discover the price of a GTX480. But anyway, after finally convincing myself it would be worth it to be able to use Octane, I then came accross a discussion here and read about FERMI.
FERMI, yeah, so here's the dumb question - what the hell is it?
I can't seem to find anything about it, yet it seems to make a massive difference to speed.
Here's the card I've decided to purchase if all is well with the spec:
http://pden.zotac.com/index.php?page=sh ... t&Itemid=1
Does this model support FERMI?
Is FERMI a software driver that would run on it, or is FERMI even a driver?
I haven't a clue about it but don't want to make an expensive mistake. I'm hoping it's got (or does) this FERMI thing, whatever it is, because that's the best card I can afford if I'm to keep within budget.
Any info on FERMI and this card would be appreciated.
Cheers,
Len.
GTX480 Questions :
pumeco
Cheers radiance, but just so I'm understanding this properly, you mean all GTX400 are FERMI cards?
pumeco
@radiance
Cheers, I'd better get that card ordered then.
@Maryus3D
Thank's for the info, and bloody hell, I had no idea they made such cards for the mobile platform as well
Those laptops must run hot!
Mind you, I think even the little 1201n from ASUS will run Octane - it has the spec!
@Maryus3D
pumeco
To be honest, the noise is my biggest concern because I'll be working with audio on the same machine
I'm also beginning to wonder if the power supply I chose is going to be enough to power that machine:
http://www.zalman.com/ENG/product/Produ ... sp?idx=344
Is that PSU powerful enough to run a GTX480, AMD 1090T, 4GB, Twin Hard disks?
500W sounds powerful enough when I read some specs, but not others.
Corsair 650HX should do the trick
. The noise depends much on fan speed. You'll need a good air flow on your case. Also there are available custom GTX 480 with zalman coolers. Check zotac GTX 480.
pumeco
Well I do like the Zalman stuff, in fact I went out of my way to make sure I chose that brand wherever possible. The PSU, the Case, the Case Fans, and the cooler - it's all Zalman and very nice quality. From your reply it sounds like 500W isn't powerfull enough, but I'll still give this PSU a chance first (seeing as I already have it). If it won't fire-up I'll just change it for a bigger Zalman PSU. I suppose I was just hoping you'd say it was powerful enough.
There's no way I'm buying anything made by Corsair, believe me, I have my reasons!
Good stuff I hear, but my experience has been the opposite.
Anyway, thanks for the tip, at least now I know to go for at least 650W if this 500W isn't sufficient
