LiveDB/LocalDB crash on open
Chrmez
I was making materials yesterday and uploading them to my LocalDB. I was just about to upload a new one, opened LiveDB and then C4D crashed.
And now it happens every time I try to open LiveDB. I've tried different Octane C4D versions but nothing seems to work.
Won't be able to do any work since I can't touch my materials which sucks :(
Here is the bug report I am getting.
https://www.dropbox.com/s/p6eb6x0361tjk ... t.txt?dl=0
C4D R18 / C4D R19
AMD Ryzen Threadripper 1950X — MSI X399 Gaming Pro Carbon
MSI 1080 Ti FE — 2 x PALIT 980 Ti Super Jetstream
Corsair AXi 1500W — Corsair Vengence 32GB 3000MHz LED White
Chrmez
Pointing my LocalDB destination somewhere else makes it work again. But as soon as I am setting it to its actual location it crashes again
so it's not really of any help to move it.
Is there a size limit to LocalDB? It is currently at 42gb's
C4D R18 / C4D R19
Chrmez
OK, finally solved it.
For anyone that runs in to the same problem, do this:
- While you are in C4D, go to your Octane Settings/Other scroll to the bottom and change your LocalDB destination to an empty folder.
- Open LiveDB and make sure it works. Close LiveDB window.
- Now go in to the settings again and change it back to your original folder.
Do not close C4D during the process. It will crash again when you open LiveDB. Do all steps while it's running.
C4D R18 / C4D R19
