All the Octane materials previews went nuts lately.
Screen cap attached.
Ahmet, as far as i understand it's something from Maxon side, but we got to have some solution for that.
Any news?
Whats going on with the materials preview lately?
4x 980ti EVGA | 5930k | Asus X99 E WS 3.1 | corsair 64GB RAM |SSD 500GB system + SSD 2TB working files + 6TB HDD storage WD |
Phanteks Enthoo Primo | 1600W EVGA T2 BLACK | It's the fastest 4x980ti build: http://goo.gl/hYp8e0
https://yambo.me
https://yambo.me
Hi Yambo,
maybe an nvidia driver issue?
ciao beppe
ciao beppe
1-If you see unvisible materials that's about me+transparent ogl implementation on latest builds. There is a bug in maxon sdk but i've kept this feature active anyway. Just i've tried to fix with some hacks as much as possible.
2-If you see weird dots, colors, lines that's a problem on renderer+driver+gpu. Not about me or maxon.
More like crazy dots, lines, artifacts.
Let's try to update Nvidia driver. As far as you guys know - Is it safe to update to 372.90?
https://yambo.me
https://yambo.me
So if I apply some simple material without any alpha or opacity and the object disappears in the viewport, I cannot do anything against it at the moment? If I reopen the file, everything is back to normal.
Gonna update my driver and see what happens
edit: ah. just disabling opacity does the trick.
Be sure that you 're using latest(R2)mrom wrote:So if I apply some simple material without any alpha or opacity and the object disappears in the viewport, I cannot do anything against it at the moment? If I reopen the file, everything is back to normal.
