Octane Render for SketchUp 3.03.3.2 Stable (obsolete)
visualmax
Hi.
There is a problem with scale.
Importing the model size = 1 * 1000
for example: try to export a cube 1000x1000x1000mm form sketchup, and then import it as proxy
fix it please.
haze
visualmax wrote:Hi.
fix it please.
Thanks for the report, we will fix this.
azen
visualmax wrote:Hi.
fix it please.
This is likely related to units of measurement. Sketchup uses the Imperial System by default, which can create issues when using metric units. We will make note of this as we explore the issue in greater detail.
visualmax
azen wrote:
visualmax wrote:Hi.
fix it please.
This is not related with units. If you do the same thing with inches. It will be the same result.
azen
visualmax wrote:
azen wrote:
visualmax wrote:Hi.
fix it please.
Thank you for the clarification. I will look further into this. I will try to zero in on this to get the fix in before the upcoming hot-fix release. At latest, it should be in the hot-fix release following that.
Return to “SketchUp”
