Errors
Refracty
Hi Paul,
there are 2 issues that popped up recently.
The first one have been two error messages popping up after starting Rhino. When I restarted the error disappeared.
The second problem was about an object where the material couldn't been changed. This was not a group - Because Octane has still problems with material edits of groups...
See the other error attached.
Any ideas?
Thank you
Nando
Hi Nando
Where these one-off errors, or reproduce-able? If they are one-off - I would suggest monitoring to see if they occur again. If you can reproduce these error, I will take a closer look.
Also - are you running the latest release? If not, I suggest updating to it, since it is the most robust version.
Return to “Rhinoceros 3D”
