Hi, can someone post an example of how to create low lying groundfog in Octane for Lightwave?
Ground fog?
I suppose that the new Octane 3 volumetrics could be used to render this kind of effects ... something like this fast example.
- volumetrics.rar
- (81.39 KiB) Downloaded 283 times
Thank you Juanjo, working great with your screenshots, didn't even need to load the scene
And it is surprisingly fast, even for me who is already used to Octane's speed
Fog is usually something that takes long time to render but this is matter of minutes (of course depends on complexity of the scene but in general)
It takes some time to do the first load but after that it is normal Octane
Antti
Antti
AMD Ryzen Threadripper 2990wx (32c/64t),64GB RAM,NVIDIA GTX 1080ti,Win10
Clarisse 4,Houdini 18 (+Octane 2019),Blender2.81,Fusion360,Onyx,ZBrush,SubstPnt...
Started: Houdini 2019, Clarisse 2016
No business, just fun
I have Octane 3.03.2.0 and I do not have the Octane_Volumetrics custom object (but I do have Octane_Object_Properties) . Everything else appears to work fine under Lightwave 2015.3.
So, obviously when I attempt to load one of the demo/example files, I get an error 'No plug-in of type CustomObjHandler found with name Octane_Volumetrics. Would you like to load it from disk?'
Any ideas regarding how to resolve this?
Thanks for your time and consideration.
Of course, I already applied the LWOctane_3.0_2015.3_x64.p file to get all of the other Octane plugins. I decided to remove every Octane relate plugin (manually) and re-add the LWOctane_3.0_2015.3_x64.p (140 plugins). But this time I have the missing plugin 'Octane_Volumetrics', which was the ONLY one missing before. Odd..
Thanks anyway..
Thanks anyway..
