Resident Evil VII: Photogrammerty @CEDEC 2016
Elvissuperstar007
I added finished material online (LiveBD) , organic section , skin, Realistic hair
linvanchene
@ Rikk
Amazing work indeed!
@ ears of the scanned models
Are we seeing transmission effects for thin walled geometry,
is refraction and subsurface scattering going on in a volume
or had the scanned models actually just red ears by default which are now on the diffuse map?
-> Is the bust open at the bottom or is there some invisible wall to create a volume to allow SSS and refraction effects?
@ Elvis
Thank you for sharing as well!
Win 10 Pro 64bit | Rendering: 2 x ASUS GeForce RTX 2080 Ti TURBO | Asus RTX NVLink Bridge 4-Slot | Intel Core i7 5820K | ASUS X99-E WS| 64 GB RAM
FAQ: OctaneRender for DAZ Studio - FAQ link collection
Rikk The Gaijin
linvanchene wrote:@ Rikk
Yes, the ears get red because of the scattering.
My skin shader is like this:
Super simple stuff. ;)
linvanchene
Rikk The Gaijin wrote: Yes, the ears get red because of the scattering.
Thank you so much for posting the node layout.
I experimented with simple Mix Material Glossy and Specular before.
Then I run into the issue that with 0.5 to .05 material weight the scattering of the specular material makes the details from the diffuse (albedo) texture in the glossy material appear less sharp. In general simple mix materials with a specular part seemed to make the whole skin tone darker.
I will have to experiment with Mix material Glossy and Diffuse (SSS) again. Before I had no luck figuring out how to make the scattering part work with the diffuse material...
Rikk The Gaijin
You might want to add a color correction node to your albedo texture. ;)
Sorel
I just want to be sure...this is a specular/glossy mix?
whersmy
Lovely to see all these techniques come together so well!
Octane 2022.1.1 nv535.98
x201t - gtx580 - egpu ec
Refracty
Impressive realistic work.
Rikk The Gaijin
Sorel wrote:I just want to be sure...this is a specular/glossy mix?
Diffuse/Glossy mix.
andrey.krivulya
Diffuse/Glossy mix.
Thank you for share skin shader settings =) Really they are very simple =) Because I tried other hard way =))
Love your work, man! It is Awesome! Every work ;)
Best regards, Andrew.
Windows 11 Pro / Intel Core Ultra 9 285HX / 96GB DDR5 / RTX 5090 Laptop 24GB / 4TB SSD / MSI Titan 18 HX AI
My youtube channel with 3d tutorials ----- >>>> https://www.youtube.com/c/AndrewKrivulya
