OctaneRender 3 for AutoCAD [OBSOLETE]
Autodesk AutoCAD (Integrated Plugin developed by OTOY, maintained by Paul Kinnane)
I have updated the installers at the top of this thread with:
3.3.4.16
- Compiled with Octane 3.03.4
3.4.1.17
- Compiled with Octane 3.04.1
- Added additional pins to the Falloff Map node as per Octane 3.04
- Added Direct Lighting Kernel AO Texture as per Octane 3.04
3.4.2.17
- Compiled with Octane 3.04.2
3.4.3.17
- Compiled with Octane 3.04.3
3.5.2.17
- Compiled with Octane 3.05.2
3.6.5.18
- Compiled with Octane 3.06. See viewtopic.php?f=24&t=60014 for details
3.6.4.19
- Compiled with Octane 3.06.4
- Added AutoCAD 2018 support
I have updated the TEST build installers at the top of this thread with:
3.7.0.21
- Compiled with Octane 3.07 TEST 6
- Fixed a geometry loading error that was arising when loading geometry created via AutoCAD plugins
3.7.0.22
I have updated the STABLE installer at the top of this thread with:
3.08.1.23
- Compiled with Octane 3.08.1 (see viewtopic.php?f=33&t=63219 for details)
- Added Toon and Metallic materials
- Toon shading only works in Camera Light toon lighting mode
- Added Custom Lut pin to the Imager node. Load .cube file into this node
- Changed the plugin version number to make it clearer which Octane release it uses
- Added support for AutoCAD 2019, and removed support for all prior versions of AutoCAD (due to a bug in those AutoCAD SDK versions)
Return to “Autodesk AutoCAD”
