Animation Camara
Moderator: BK
Hi all, im trying to render an animation with the plug in, i set the render setting to 640 x 480 renders fin as a still, try to animate and the camera clips the iamge and really is not even close ive tried to select and unsellect "To Preferd size / Size form Render setting but no luck. Anyone know what im missing here?
Win 7 64bit, Titan 6 Gig and GTX770 4Gig, Intel 3.75GHZ, 24Gig RAM, Poser 2014 patched
When asking a support question, can you pls provide the info requested at viewtopic.php?f=44&t=55214 - particularly the plugin version you are running.
- Operating System - Windows 7
- Amount of RAM - 32 Gig
- Graphics Card(s) - 4 X GTX 980ti
- Nvidia driver version - 353.3
- DAZ Studio version - 4.8 pro
- OctaneRender for DAZ Studio version (ie. 2.24.2.1)
Daz Octane plug in version 3.0.20
As mentioned the resolution and cam settings are fin rendering any frame in teh animation as a still, once i "render animation" the render dimensions are not even close like its not useing the selected cam at all focus is off too,.
Can you try the latest TEST release pls. It should resolve your issue.
yes that solved the resolution sizing thank you
When rendering out this animation the focus now randomly changes, do i need to set that differently, I am using the view port picker to set focus to an object in the scene but frame by frame that seems to not stay consistent.
It is probably rendering with AutoFocus ON. Create a new camera, and set the desired focus setting in the Viewport (there are 3 buttons for this).
