Setting up Octane Render with the new Geforce 1080s.
Real2Reel
Morning Everyone,
I wanted to reach out and see how people have got Octane Render to recognize the new geforce 1080s. I have two installed and Can't seem to work around the issue. If anyone can pass on some wisdom, I would greatly appreciate it.
Cheers,
rappet
Are you running OctaneRender 3?
I think I have read on the forum that Pascal works from v3, not v2.
Edited: in the meanwhile I have browsed the forum and it look like you need version v3.03.2 and above for Pascal.
4090+3089ti & Quad 1080ti
http://www.tapperworks.com
smicha
That's right - 3.03+ needed. Run clean install of nvidia driver when inserting the second card BTW.
Real2Reel
Smicha,
Clean install - Like uninstall all the drivers and then install again for both or just one? Using Guru3D?
Furthermore, I got the v3 but can't find the folder to paste in the C4D plugin's folder. I have the Octane render installed and the standalone works but am I missing something for the plugin to show in C4D.
Thanks again for the help guys.
Cheers,
smicha
Real2Reel wrote:Smicha,
Cheers,
Clean install is the option when installing nvidia driver.
As for C4D - ask in the plugin topic for further help.
rappet
I do not know about the c4d plugin, so cannot help you there.
So, you got the standalone... also make sure the plugin is based on v3.03.2+.
Good luck with getting the plugin working
Cheers,
I think you missed installation notes. Please check readme.txt in archive.
