OctaneRender 3 for Modo [OBSOLETE]
smicha
Paul,
I turned on modo render cache on in preferences and modo proxy works and they (objects) are visible in the viewport (I mean - modo lxo proxy files). But when I want to move proxy modo crashes. If you need any info please let me know.
Cheers,
smicha
MrFurious
Scroll zooming under the mouse pointer doesn't seem to work regardless if its in a floating window or a fixed layout, or the stock default octane layout (I reset my config to default to test under default conditions) Hopefully this can be working again soon.
Cheers,
dino.
Dino Inglese
CG Artist
Melbourne Australia
Intel Core i7-4820K, 3x GTX 980ti
Windows 7 64bit, Modo 12.2v2 for PC
Octane build 4.04.0.145
Uhlhorn
face_off wrote:… 3.3.3.112 (11-Aug-2016) …
It’s running nice! :-) But the Modo plugin is not remembering the tone mapping setting.
MrFurious
been getting this error today, no idea why.
Modo will then crash immediately after.
EDIT:
I found the problem, turns out there were a few 'ghost' instances, never seen this type of thing before. But after deleting them the error went away.
rogue instances.jpg (91.38 KiB) Viewed 10481 times
Dino Inglese
CG Artist
Melbourne Australia
Dino - can you send me a scene with a ghost instance pls, and I will fix the crash.
This is a Modo bug (and I can reproduce it without having the Octane plugin installed). I have reported it to TheFoundry.
Can you be more specific pls? Which exact setting are you referring to?
It is fixed in the next release for the Octane Layout.
smicha
Thank you Paul for reply. If there is any news on please post it.
MrFurious
No problem you can find the scene here:
http://www.mediafire.com/download/14p4t ... _scene.zip
Cheers,
Dino.
Dino Inglese
CG Artist
Melbourne Australia
Uhlhorn
The zoom with the scroll wheel is now totally broken in this version. If I zoom in, the frame jumps always to the left.
MrFurious
Paul[/quote]
Yes!.. awesome.
Dino Inglese
CG Artist
Melbourne Australia
Return to “Foundry Modo”
