Render info channels only?
niestudio
Is it possible in C4D to render info channels only?
I have Render passes enabled with Render Layer & Object ID checked.
I have Save in the left column unchecked, but when I render to picture viewer it still renders a full color image before it renders the render layer.
My only workaround so far was to set the max samples to 1 so the beauty render is fast since I don't need it again anyway.
Normally this may not be an issue, but I realized I needed the info pass after the fact.
Grateful for any insight.
Daniel
OSX 10.12.4 | Intel 12 core @ 3.33 ghz | 128 gb ram | NVIDIA GeForce GTX 1080TI | Ubuntu Linux slave with 3x 1080ti
Not possible. Also it would not increase the render speed if that's even possible. You're doing fine with maxsamples=1.
niestudio
Thanks.
