Animated gradient
fpajonk
Hi everyone,
I have small problem with a C4D texture. I have an animated gradient that moves from the center of on abject to it's outer ends.
If I convert the texture to an Octane material everything is fine except that the origin of the animation is way off center.
Is this a bug in how Octane converts materials or is it just my ignorance?
Frank
It will not work as you expected if you're using c4d gradient without uvmapping. C4D shader are prerendered as images and used as an image map.
fpajonk
Excellent! That helped a lot!
