Version 3.03.3-R1 (11.08.2016)
atome451
aoktar wrote:
atome451 wrote: Ooops. Sorry. My mistake. :oops:
Anyway, just for my information, why it has been removed? Deprecated?
yes. what do you want to obtain?
I wanted to use a gradient in opacity of hair. But, as it's not possible, i've used a spline in the thickness. I think the result is event better in this case. Then everything is fine.
Thanks for your fast answers. :)
Win10 64bits | 3x 980 + 2x 670 + 1060 | Cubix XPander + network | Core i7 3600 MHz | 32GB | 1300w PSU
Sorry for my bad english...
atome451
About function "Save C4D Scene With Assets" from Octane dialog > Menu Files, it seems to be broken. It seems to only save assets that aren't in preferences Path, even if the Octane Texture Manager find all assets. My system is in French but my C4D R17 Studio is in English, maybe it's an explanation...
Anyway, the standard C4D "Save Project with Assets" seems to work fine even with Octane materials (but i have no .ies light in my actual project then the test isn't fully complete).
atome451 wrote:About function "Save C4D Scene With Assets" from Octane dialog > Menu Files, it seems to be broken. It seems to only save assets that aren't in preferences Path, even if the Octane Texture Manager find all assets. My system is in French but my C4D R17 Studio is in English, maybe it's an explanation...
It comes from old versions. I'll remove it. Thanks for report. That's strange that nobody report it properly.
EDIT: I've checked that for texture from PATHS. It seems like working. can you check again?
ramiz
It works with my 1080.... YEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEESSSSS!!!
atome451
Very curious. It seems to work fine on my Desktop but not my Laptop...
Sorry for the wrong information. I need to investigate my own systems. :?
David_S
If I export a scene to an .ocs or .orbx, the camera node is gone (see screenshots). Do I something wrong?
I am on OS X, R17, Standalone 3.03.2b and Plugin 0.03.2-R4.
Hi David_S,
you can select multiple camera in c4d and export them in alembic separately from c4d export menu with this settings:
then, you have to change the scale from meters to centimeters within Standalone by clicking on the Edit setting button of the imported alembic node:
ciao beppe
David_S
Ciao Beppe, that seems to work. Thanks.
So it is currently the only way to export Cinemas camera position and settings?
David_S wrote:Ciao Beppe, that seems to work. Thanks.
No. That's an old command and it's ignored for some time. You can use animated orbx export OR wait for next build. I may try to fix.
eyeonestudio
Thanks for R5...
Recently there is a lot to with the "Vertex Map" feature.
Is the planning of the "Vertex Map"? :P
C4D R2026 / Win11 / AMD TR WX Series / 256Gb RAM / RTX 5090 FE / 100GbE
Return to “Releases”
