Version 3.03.3-R1 (11.08.2016)
luoluokk wrote:when I open Cinema 4D with v3.03 ,it appears a window "could not get a license because your sso session has expired , and let me re-enter password" , i input the password for several times but i can't log in yet.
but when v3.02 , i login successfully but due to my graphics card gtx1080 , v3.02 can't run.
Did you used offline sso method with 3.02?
luoluokk
2 days ago i used and found that it need to unlock the license which only has 5 times for unlock so i do nothing finally because i think the counter is important
Unlock is for emergency cases like when you don't have access to activated machine. For example formatted windows or changed hardware, etc...
You should deactivate license with the version which is used for activation. Later you may run with newer version.
luoluokk
thank you very much ,now i sign in online successfully after i signed out and v3.03 runs very well n_n
Hi everyone,
Plugin has been updated to 3.03.2-R3 with some fixes. See first page. Enjoy!
lilbignik
Hi. Found small bug. When add any texture to opacity channel in glossy material, main color changes. In render it looks correct, but in material viewport not.
Look my pic.
Sorry for my English
Win 10 x64 / amd fx-9590 5.0Ghz / 3xGTX Titan Black 6gb/ 32gb / ArchiСad 19 / Cinema4D R17 / latest Octane.
lilbignik wrote:Hi. Found small bug. When add any texture to opacity channel in glossy material, main color changes. In render it looks correct, but in material viewport not.
Look my pic.
Thx
milanm
Hi
I found a small issue with opacity and polygon selections.
Opacity is lost after adding a falloffmap on a glossy material.
It happens in both 3.03.2-R3 and R2
OpacityIssue.zip
(151.26 KiB) Downloaded 317 times
Milan
Edit:fixed the sound issue in the video
Colorist / VFX artist / Motion Designer
macOS - Windows 7 - Cinema 4D R19.068 - GTX1070TI - GTX780
milanm wrote:Hi
OpacityIssue.zip
Milan
Fixed on today's build. 3.03.2-R4
aggiechase37
Probably doesn't make a difference, but my Live viewer keeps displaying the wrong plugin version number when I install a new one. Should I be worried?
Chase
Win 10 - Intel 4770 - 2x Nvidia 1070 - 32 gigs RAM - C4D r16
http://www.luxemediaproductions.com
Return to “Releases”
