Crash with cubix xpander
enricocerica
I have a strange problem with my Cubix xpander.
I have two gtx580 on it, if I activate both cards in Octane it crashes sometimes immediately, sometimes after several minutes, sometimes after an hour, but often as soon as I activate both cards it crashes immediately with a blue screen or one card fails.
I first thought one of the cards was defect but if I only use one of them changing alternatively the activated card it works fine.
I have the last Nvidia drivers, tried with previous versions and got the same issue, though I didn't installed very old one.
Any idea ?
Modeling system : I7 32GB Windows 10 & Fujitsu Celsius H720
GPU : 1x Gigabyte GTX580 3GB + 1x MSI GTX780 3GB + 1x PALIT GTX780 6GB +1x Asus Stix GTX1070 8GB
http://www.myline.be
whersmy
Maybe the psu is somewhat faulty?
You can try checking with less power hungry gpus plugged in if it remains
Check with afterburner how the power usage is with just one 580, and two, to see the stability of it
Did the problem just happen out of nothing?
Octane 2022.1.1 nv535.98
x201t - gtx580 - egpu ec
enricocerica
Thanks Wersmy,
It worked fine some times ago, duno exactly when it started to bug ...
Will try what you suggest.
enricocerica
Well I reduced the clock for both the cards and it seems much more stable.
So you may be right, the PSU is probably the origin of the issue, will try to change it.
