Ok Thanksface_off wrote:Yes, that's correct - you need the material (Octane Override) to be being used in the scene before it can be edited. I will try to remove this limitation in the next month or so.When I click on edit node graph, octane nodegraph dont open if I create a new material and keep the octane viewport open.
OctaneRender 3 for Modo [OBSOLETE]
Can I access or download the octane livedb without having the standalone version? I only use the modo plug in. The documentation doesn't really say much and it looks like the process of accessing the live database was changed a few months ago. Please let me know.
Thanks again for all the help.
Edit:
Nevermind. I will just use octane standalone for it. Thought it was going to use more ram but it's fine.
I don't see where to scale the noise texture though. It doesn't show it like the video
Edit:
Paul,
Update on mouse button release unticked does not update on the fly the viewport.
Another thing with node graphs - is there any chance to add plugin inputs from standalone node graphs in modo automatically? Please take a look at the screenshot.
It might take a Refresh in order for this setting to take effect. What specifically is not updating on the fly?Update on mouse button release unticked does not update on the fly the viewport.
This is a good suggestion - but something I would prefer to put on hold for the moment. It's possible the Open Shader Language implementation may change how the NodeGraph is implemented in the plugin.Another thing with node graphs - is there any chance to add plugin inputs from standalone node graphs in modo automatically? Please take a look at the screenshot.
I meant the the viewport is not updating while changing a scene but only when I release a mouse button. See the screenshot. (PS sorry for error 'keep holding' not 'holgind'.)face_off wrote:It might take a Refresh in order for this setting to take effect. What specifically is not updating on the fly?Update on mouse button release unticked does not update on the fly the viewport.
Yes, regretfully whilst holding the mouse button down to move the camera, Modo withholds all updates until you release the mouse button. Yes can see this if you look at the camera transform in Modo - it is only updated when you release the mouse button. So this is a limitation of Modo.I meant the the viewport is not updating while changing a scene but only when I release a mouse button.
Thanks Paul.
I just thought that the 'update on mouse button release' is responsible for that. Anyway thank you so much for your fantastic work and awesome plugin. I am slowly getting used to it moving from the Standalone.
Below is a pre-release of the next version, for users wanting to try new features (which may or may not be robust).
3.3.2.112
- Changing the Render->Frame->Resolution Units now correctly reframes/rezooms the Octane Viewport
- Changes to a Morph Influence now trigger a reloading of the parent mesh if that mesh has Live Geometry Update enabled
- Added octane.uploadFrame to upload the currently rendering scene to the OctaneRender Cloud. The upload status is in the render statistics. octane.cancelUpload will cancel the upload
- Renamed "Load All Frames Into Octane" to "Object Motion Blur"
- Added "Camera Motion Blur" checkbox
- EXPERIMENTAL: Added Proxy meshes to Modo Item items. This allows you to specify an OCS or ORBX file in the Mesh->Octane properties and the mesh item from that file will be rendered instead of the Modo Mesh item. This is only available if Live Geometry Update is OFF.
- Added "Use Checkerboard For Alpha" to the Preferences->Octane panel
- The octane.saveAnimation command now deletes the temporary ABC file created if exporting to the .orbx format
https://render.otoy.com/customerdownloa ... _64bit.exe
3.3.2.112
Paul,
You are the man! ocs and proxy
I'll test is asap while back from vacations.
