I use lightwave on one computer and use another computer as a slave so i can network render.
I currently own 2 standalones and 2 lightwave plugin licenses.. i think i might have been a little confused there at the time i bought them.
to keep my current setup, all i need to do is upgrade 1 standalone and both plugins.. Is that correct?
Steve
Quick question before I upgrade
If you are using the plugin in only one computer, and the second computer is used only for rendering using the Octane native network rendering, you need to upgrade one plugin license and the two standalone licenses. In the render node you only need the Standalone for the network rendering.
But if you want to use LWSN in the render node (or render using the Layout), you need to upgrade both Standalone and plugin licenses for this render node. I think that the combo upgrade (plugin+standalone) can be done for only 75$, what is not bad at all
