Realflow C4D Crashes with Octane
xantirodriguez wrote:Hi Guys,
I´m having the same issue as you, it started OK with the first update that aoktar uploaded weeks ago ( i have some animations rendered ) but actually i can´t do nothing if i want to render a saved scene, with cached fluids, first i tought that maybe could be because the subdivision of the mesh but even i work with the lowest quality and with no particles in the scene ( from the moment that i have a Realflow tree in the object manager it crashes ).
I´ve downloaded the latest version of the Octane plugin ( the 3rd update ) and still continues crushing...
Working with R17.
Quite frustrated arggh...
I can't see any advantage to post like that. Always post something with a bugreport first. It show where it crashed.
If it's not enough post your scene and full details of software and hardware. Otherwise just a chaos and mix up with plugins.
xantirodriguez
Yes, you´re right, apologies.
Here you have the screenshot when it happens and the TXT file of the crash attached, let me know if you need something more.
Thanks mate.
_BugReport.txt
(212.7 KiB) Downloaded 269 times
xantirodriguez
Screen capture
xantirodriguez wrote:Yes, you´re right, apologies.
Thanks mate.
could you send me this scene?
xantirodriguez
Just sent as PM,
Let me know if it runs properly, if not i could send it back to you.
As detail, I´m using LUMINOUS " Plugin " for this scene, maybe this could be one of the reasons for crashing ?
Thanks for your help
xantirodriguez wrote:Just sent as PM,
Could somebody try 3.03.2 build for windows? I've made a new build with new sdk. Thx
xantirodriguez
Hi, redownloaded the 3.03.2 build but still giving the same crash, i used the scene that isent you for testing,
I'm testing with your scene and works fine on me.
xantirodriguez
Will try it again, let´s see what happens, i will let you know about mate.
Thanks for your help.
seb6996
Hi Aoktar
Same problem on OS X on R16 with the 3.03.3-R1 plug-in > Crash when hit the render button.
Will it be fixed in the next version of the plug ?
Thx
Locked
