Bug sequence (3.02) [SOLVED]
Elvissuperstar007
something strange is happening with animation frames, the first frame begins with a frame 30, the first image pops up as a bug
Hi guys,
Octane Standalone just reads what is inside the alembic file, so is not a Standalone issue but more likely an alembic export problem in the host app.
Here is a simple scene exported from c4dOctane in .orbx format with alembic file:
AlembicExport2.orbx
As you can see, there is no dropped or jumped back frames.
ciao beppe
amoh
I have the same problem....
Look I download your scene and it's the same problem
Video_1 - your scen
Video_2 - my simple scene
2017_1.ABC - my simple object
2017_1.OCS - project octane 3.02
Hi amoh,
weird, I have successfully rendered your scene and the mov has no jumping-back frames :roll:
Just an idea, but what about the frame naming?
Under mac there's no issue, but I guess that the numbering of the frames could be the issue under Win :roll:
What happen if you remove the first ten frames and load the animation in AE from 10 to 80?
ciao beppe
amoh
Hi bepeg4d,
Yes! It's helped!!!
Thx :D
amoh
How to made file name like 00001,00002,00003 in output octane sequences?
UP
I find)
In Batch rendering => Filename template => change %f to %F
stratified
Elvissuperstar007 wrote:something strange is happening with animation frames, the first frame begins with a frame 30, the first image pops up as a bug
Hi Elvis,
Thanks for the detailed video! This is not really a bug.
Like Bepe already pointed out. The problem is how the files are sorted based on their file names. If you use the %f option which inserts the frame number in the file name, then we don't prefix the numbers with 0s. This means that you will have a file ordering like this:
  • target_109_0
  • target_10_0
  • target_110_0
While when you use the %F option, we prefix the file names with 0s. That means you would get something like this:
  • target_010_0
  • target_109_0
  • target_110_0
We will change %f to %F in the default pattern because it's more useful like that.
cheers,
Thomas
Return to “Commercial Product News & Releases (Download here)”
